Bulbous Bow Cb
Discussion in 'Boat Design' started by nmfb105, Sep 15, 2009.
  1. nmfb105
    nmfb105 New Member
    Hi
    Just wondering how you define a ships Cb when a bulbous bow is involved.
    Cb is usually defined as
    Cb = V/ (Lwl x Bwl x T)
    [Volume over Waterline length by Waterline Breadth by Draft]
    However with a bulbous bow involved your waterline length is shorter than you immersed waterline, hence you have some displacement volume outside of your defined waterline block.
    so my question is from what length point do you define your "Block" witha bulbous bow?
    Any help or info appreciated
    Cheers
    Nick
  2. Ad Hoc
    Likes: 1,971, Points: 113, Legacy Rep: 2488
    Volume is volume.
    What do you think the volume is for the Cb, for a dreadnought destroyer, or a SWATH!!??
    The term 'block' in these instances is bit of a misnomer.
  3. jehardiman
    Likes: 1,472, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    As Ad Hoc said, volume is volume.
    Traditionally, a bulb is an appendage, and like rudders and bilge keels is not considered part of the main hull for the volumetric coefficients. So the Cb is defined in the traditional way with the LwL measured from the Fwd Perpendicular, which is placed at the Design Load Waterline, and at this draft the bulb should be submerged. If it isn't submerged, it isn't functioning as a bulb bow.
    FWIW, I doubt that the additional volume of a traditional bulb bow will change the block more than 0.005. If it does, then it is not a bulb, but part of the main hull.
