troy2000
Senior Member
- Joined
- Nov 3, 2009
- Messages
- 1,738
- Reaction score
- 170
- Location
- California
I should mention that I have that jig screwed to the saw backwards. It would have made more sense to attach the saw to the narrow side and lay the wide side on the plywood, since both sides were run through a jointer to make them smooth and straight anyway. No big deal; it works either way.Interesting thread. I liked the circular saw scarfing jig, neat idea to take off the material from the bottom, it would solve the problem I had keeping 3 and 4 mm marine ply sheets flat, and much simpler than the jig I tried. Just in time for the next build I have planned!
Yes, the planks are parallel-sided; 11 1/8" from end to end. I thought about tapering them an inch or so from stem to stern like a small sharpie, and decided I was getting carried away...The sheer planks look like they have straight, parallel edges: is that the case? Then the sheerline and rocker is determined by the flare angle and the plan curve. This is something I have tried and got good results with.
Since those side planks are soft pine, and planed down to a hair less than 1/2" (1.25 cm), I'm a bit leery about nailing anything too aggressive into the edges of them--even with pre-drilling. I have some small hot-dip galvanized nails that will probably work just fine, particularly since the chine will be glued with PL Premium anyway. I'll also be gluing on a small outer chine log, to cover the plywood edge. That should add a little support also. If we start stomping the bottom out I'll dig up some epoxy, tape the outside and fillet the inside. Hopefully it won't be necessary.I read that ring nails are good for attaching the bottom ply to the sheer planks; you may want to try them.
The cost of glue isn't really an issue for a boat this small and this simple. I bought a five-dollar bottle of Gorilla Glue, and I'll probably have half of it left when I'm done.Like most of the builders on the forum I am not a fan of Gorilla glue although I used it on my first effort; it worked OK for a dry docked boat but too expensive.
I hope I'm not calling the Gods down on me with my arrogance, but that's not a problem. I'm the son and grandson of carpenters and builders, and I've worked in wood all my life. My glue joints don't have gaps.Also although it fills a gap, it does so by becoming a foam and expanding, which makes it much weaker, so for a strong joint it does require a fairly good joint fit. But too much pressure and it squeezes out, unlike thickened epoxy.
And if you have more than just the barest minimum of squeeze-out, you're using too much Gorilla Glue; it's nothing like epoxy. For proper strength, you want a close fit and a very thin layer of glue. And it needs firm clamping pressure for an hour or two. Otherwise, its tendency to foam and expand can actually push joints apart, creating the gaps it isn't good at filling....
Nothing seems to work really well on end grain, not even screws! Epoxy can be made to work however. I have tried warming the wood before applying the epoxy and letting it draw into the grain as the wood cools, adding more as required. A thick epoxy works best but not too thick, a balance has to be struck between having it all soak into the grain or not penetrating enough to match the strength of the wood. My theory is, the glue only has to penetrate about twice as deep as the average pore diameter, which is not very far at all.
You're right about end grain. I didn't really have much hope that the glue I was using between the frames would hold anything; for that I'd have needed half-lap joints instead of butt joints. But I soaked the glue in anyway before screwing the frames together, in the hopes that it would at least seal some water out of the joints. Of course, the real strength is mostly in the glued plywood gussets.
