Build a wooden Jon Boat
Discussion in 'Wooden Boat Building and Restoration' started by WidowsSon, Jul 10, 2022.
  1. WidowsSon
    Likes: 1, Points: 3
    WidowsSon Junior Member
    Hello all. I use to own a 14’ aluminum flat bottom boat but I sold it years ago because my ex wife….well never mind all that. Anyhow, I started looking for another one and I’m having no luck used or brand new. I’ve always wanted to build a boat so here I am. I have 25yrs of woodworking experience, a shop with everything I need so I figure why not. I think I can design and build my own but one thing that I can’t wrap my mind around is how to figure out where the water line will be. I plan to use 3/4” oak or maple for the transverses and transom, cedar or pine planks and glass it. Maybe 3/8” ab plywood not sure yet on that.
    Length 14’ or 16’
    Bottom width 44”
    10 degree angle on the hull
    It will not have cross section seats just a deck. Maybe some type of bench that goes lengthwise so I can easily walk from front to back.
    Is there a formula to figure out where the water line will be?
  2. WidowsSon
    Likes: 1, Points: 3
    This boat will be modeled after your basic rectangular shaped flat bottom aluminum boat. I’m not sure yet if the front will be flat or not. Will be using it on small lakes and rivers for fishing
  3. WidowsSon
    Likes: 1, Points: 3
    Also I will probably put a 10 horse motor on it as my old boat had a 7.5 Johnson seahorse and it lifted the front end up so I’m assuming it should be sufficient but I could be wrong any input on this build would be greatly appreciated
  4. WidowsSon
    Likes: 1, Points: 3
    It is somewhat for aesthetic reasons but mostly that I don’t want to put all the time money and effort into this and then the gunwale be only 2 inches off the water
  5. Blueknarr
    Likes: 461, Points: 83
    Blueknarr Senior Member
    First calculate the weight of the finished boat loaded with people, lunches, tackle boxes, fuel everything.
    Fresh water weights 62.4 lbs/ cubic foot
    Calculate how many cubic feet of water exactly equals the weight of the loaded boat.
    Use geometry to find where that volume fills the bottom of the designed boat.
    That is your water line.
  6. WidowsSon
    Likes: 1, Points: 3
    Ok I’ll try that. Thank you!
  7. WidowsSon
    Likes: 1, Points: 3
    I’m not sure if I should start a new thread for every question I have. I’m wondering what the proper thickness of the transom should be.
  8. messabout
    Likes: 592, Points: 113, Legacy Rep: 1279
    messabout Senior Member
    Widowson, please do not design your own boat. I promise you that you will save time, save money, avoid numerous headaches, and have a better boat by using an established set of professional plans. There a plenty of plans that cost only a pittance and more than a few of them are free.
    DogCavalry and bajansailor like this.
  9. bajansailor
    Likes: 1,788, Points: 113, Legacy Rep: 37
    bajansailor Marine Surveyor
  10. WidowsSon
    Likes: 1, Points: 3
    Yes. I can build a house but I’d never do it without a plan and I wouldn’t pretend to be an architect just to save a few bucks. Pretty sure I’m going to get the plans for the GF-16 duck boat from the link you sent. Thank you both for the replies and saving me tons of money and trouble.
    bajansailor likes this.
  11. bajansailor
    That GF-16 does look like a nice design - here is the study plan for her on their web page.
    https://www.boatbuildercentral.com/StudyPlans/GF16_STUDY.pdf
    You might also find one or two interesting designs here -
    Outboards-boatdesign https://www.boatdesigns.com/Outboards/departments/10/
    Or in the Ken Hankinson designs section -
    Ken Hankinson boat designs for the beginning boat builder https://www.boatdesigns.com/Hankinson-Designs/departments/718/
    Here is a free set of plans for a Finnish punt (which is very similar to a Jon Boat) -
    A 15'8" fishing punt | Free Boat Plans https://hvartial.kapsi.fi/wpunt/wpunt.htm
    And here is a 16' punt / jon boat type from Duckworks -
    16' Curlew Motor Punt Plans https://duckworks.com/16-curlew-motor-punt-plans/
  12. WidowsSon
    Likes: 1, Points: 3
    Thanks so much for all that info! I’m drawn to the style of the GF-16 but I like the 15’8” fishing punt because it doesn’t have the center seat. That was the one thing I didn’t like about my aluminum flat bottom. Although that is where the live well was located. Wonder if a live well is possible in the stern area??
  13. bajansailor
    It is possible - but as always, the answer is 'it depends......' on various things like size (especially width and depth), and the effect of the tank on the stability and trim of the boat.
    How big, realistically, a tank would you need for a live well?
  14. WidowsSon
    Likes: 1, Points: 3
    I’m thinking 3 or 4 gallons would be sufficient.
  15. rnlock
    Likes: 66, Points: 28, Legacy Rep: 10
    rnlock Senior Member
  1. Chris06
  2. lotronuts
  3. Gone Ballistic
  4. First class repairs
  5. Nomiddlename
  6. TomA
  7. Brian Fredrik
  8. johnnythefish
  9. Boracay
  10. John Perry
