Bucket Controls? Help!
Discussion in 'Jet Drives' started by jacbee007, Jun 15, 2008.
  1. jacbee007
    jacbee007 New Member
    HI , CAN ANYBODY HELP WITH ANY INFO ON MY EX ARMY JET DRIVE BOAT? THE BOAT LOOKS VERY SIMULAR TO A U.S BRIDGE ERECTING BOAT BUT HAS A GRP HULL,I THINK THE ENGINES ARE 212HP FORD SABRE TURBO DRIVING TWO DOWTY MK1 JETDRIVE UNITS WITH 4 RUDDERS BEYOND (DONT KNOW IF IT IS A ONE OFF PROTOTYPE OR IN REGULAR USE?) ANYWAY THE BOAT IS COMPLETE MINUS THE CONTROLS FOR THE JETDRIVE BUCKETS. I DO NOT KNOW WHERE TO BUY OR WHAT TYPE OF LEVER SET-UP IS REQUIRED TO OPEN AND CLOSE JETDRIVE BUCKETS, WOULD A REGULAR MORSE CONTROL BE ANY GOOD AND CAN SOMEBODY ADVISE ON WHETHER THERE IS MUCH STRESS WHEN CLOSING BUCKETS FOR ASTERN PROPULSION(ie, DO YOU HAVE TO WRESTLE LEVER CONTROL OR IS IT A SMOOTH OPERATION?) AND DO YOU HAVE TO HAVE MINIMUM REVS WHEN OPENING OR CLOSING BUCKETS?................I REALLY WOULD APPRICIATE SOME KNOWLEDGABLE ADVICE, CHEERS.
  2. flydeep
    flydeep Junior Member
  3. CDK
    CDK retired engineer
    Look at a Morse catalog, cp-performance.com or american-turbine.com.
    You need a special special control unit for jets and a heavy duty cable.
    Shifting requires a lot of force when the rpm is high, less at idle, but you can do as you like: the bucket is strong enough.
