Buccaneer 24 Trimaran
Discussion in 'Multihulls' started by Samnz, Dec 1, 2008.
  1. redreuben
    redreuben redreuben
    To satisfy your curiosity see the 28 thread, plans are available for free.
  2. oldsailor7
    oldsailor7 Senior Member
  3. outside the box
    outside the box Previous Member
    Plan updates to the buck 24 test mule have started for those interested in the usual place also a table of off sets have been prepared for Sams beams we are just awaiting the engineering to be revised to accomodate the increased loadings from the float modification and a factor of safety once this is done full cad plans will be available along with all other plan upgrades including home build composite mast plans both hightec ( for the racer) and low tec for the cruiser https:// m.facebook.com/profile.php?v...925457790&_rdr
  4. outside the box
    Further updates to the float stern area cleaning up the lines.
  5. redreuben
    redreuben redreuben
    Could you post the drawings on here please, unreadable on FB.
    :D
  6. outside the box
    Hi Reuben. will put them up when have lines finalized in cad presently roughing it all out so is simply built still.
  7. outside the box
    Reuben and others who emailed off here we took a moment to darken the lines which can now be viewed at the link in above posts.
  8. outside the box
    Work on the plans is a priority as we have a build slot available to get the building work done on it. Beam updades just posted in the usual place. Beams and floats are now about ten hours away from being finalized in cad.
  9. outside the box
  10. outside the box
    Beam cross sections added in the normal place onto new float lines now....
  11. bruceb
    Likes: 41, Points: 48, Legacy Rep: 214
    bruceb Senior Member
    Nice progress
    OTB, nice to see you have some time for the Buc :)
    B
  12. outside the box
    Hi Bruce.
    It is nice to be back at it full steam ahead again have had a long run of bad health so sold the business life is easy now.
    Have the beam plans getting put in cad and 3d modeled so building will be clear and concise plus full photo documentation of our build will explain alot to any would be builders. updates just put up in the usual place.
  13. ikimalu
    Likes: 1, Points: 3, Legacy Rep: 15
    ikimalu Junior Member
    plans B24 for those who are interested
    Hello all,
    unfortunately we were not able to salvage our B24. It has lost the battle, was to far gone to be rescued.
    We have a complete set for building the B24, bought from oldsailor. We will not use them, because we will stick with our Strider catamaran.
    If you are interested, send me a pm.
    Kind regards,
    Sipke
  14. oldsailor7
    Sipke.
    I am very sorry to hear that , as you say, "you lost Your battle" with rescuing your Bucc.
    I am sure someone else will benefit from you passing on your set of plans.
    At least you tried. Good on you. :cool:
  15. outside the box
    Sipke such a shame, our old girl was found under trees no water within miles. At least you tried to save the old girl.
    For those interested the journey of our Buc and the new float plans are progressing with the bow profile coming together. Details in the usual place. https:// m.facebook.com/ 2128219254577...pe=1&source=46
