Buccaneer 24 Builders Forum
Discussion in 'Multihulls' started by oldsailor7, Jul 22, 2009.
  1. oldsailor7
    oldsailor7 Senior Member
    This is a very interesting paper on the design of boards and rudders by Bernard Kohler.
    He covers sections, plan forms, aspect ratio and skin friction matters in a very understandable way.
    http://www.ikarus342000.com/Boardsandrudders.pdf
  2. bruceb
    Likes: 41, Points: 48, Legacy Rep: 214
    bruceb Senior Member
    Thanks
    Thanks for posting that, i had not seen it. B
  3. oldsailor7
    Thanks Elkclan. I said you would be the first to know. :)
    Due to continued demand for these plans I will be producing five sets later this week. Please contact me by private mail with details.
    Others please note I now have three confirmed orders, so two will be available.
    Nothing has changed except the price is now US$155.00 due to international currency rate changes.
  4. ikimalu
    Likes: 1, Points: 3, Legacy Rep: 15
    ikimalu Junior Member
    Hello all,
    I saw this modification on youtube, cutthroatjake
    http://www.youtube.com/watch?v=6JlgG6dMF6w
    is that a recommended mod? Or will it cause extensive wave slamming or other negative aspects....
    Kind regards,
    Sipke
  5. oldsailor7
    No. It's not a recommended mod, but that said it will give you more room in the main hull and won't be a problem in smooth waters.
    In rough waters I don't even think it will slow the boat down----but it will be very noisy in that drum like cabin. :eek:
  6. bruceb
    hull bumps
    I have seen pictures of several other Bucs with hull/cabin "bumps", so it is not the only one. I am sure adding real sitting head room is very nice in the cabin, as long as it doesn't adversely effect the sailing performance, and might be better than building a taller cabin top. I do know that the 24 already rides low, and those bump-outs are going to be in the waves in most conditions. They may not hurt much- many newer designs are doing something similar. For sure, they must not be allowed to add very much weight as the 24 can't carry any extra. Air space inside won't hurt, but you can't fill it with an extensive interior and expect the boat to sail very well. Bucs are light and HAVE to be kept that way. My boat's max useful load is about 600 lbs crew and gear, and likes a lot less. B
  7. 3burritos
    3burritos Junior Member
    Buccaneer 24 Plans
    I am interested in the Buccaneer 24. Five posts / five questions:
    Does anyone know of any B24's in the PNW of USA?
  8. 3burritos
    What is the approximate finished weight?
  9. 3burritos
    Buccaneer 24 Plans
    I see lots of modifications. Is there a list summarizing the "best changes"?
  10. 3burritos
    Buccaneer 24 Plans
    Is the B24 much faster than the Tremolino?
  11. 3burritos
    Buccaneer 24 Plans
    Is there a better plan out there for cruising at this length?
  12. cavalier mk2
    cavalier mk2 Senior Member
    What kind of cruising do you like? Some people like to put a deck tent on a Tremelino and get there fast, others want more room, a drier ride and don't mind a less frenetic pace. Do you need to disassemble/fold? Contrast the Bucc with the Horstmans in that size and look up the Searunner 25. I'm thinking a Tremelino has a higher top speed but Hughes would say he has one that is faster than both. Check out the website for smalltrimarans for other ideas. The Bucc does have something special to it though..
  13. 3burritos
    Cruising Needs
    I haven't owned a sailboat for many years. Right now, my ideal is probably the Trinado built in Port Townsend.
    http://www.biekerboats.com/Bieker_Boats/Trinado.html
    But plans aren't available. I am looking at options. I have time to build right now, but not sail. Thanks for your reply.
  14. Corley
    Corley epoxy coated
    One of the members of the board built a trinado based trimaran (aussiebushman). The tornado hulls used as floats in the original design proved to have inadequate buoyancy so the new floats were built (designed by Nigel Irens).
    I dont want to be negative but my question is why build it then? You are still going to have to build a complete trimaran and there is no real labour saving, better to build something that is a bit more liveable with less compromises. If your concerned about building crossbeams the Bucc24 or one of Kurt Hughes aluminium tube and waterstay trimarans would be a better proposition.
    This is all imho of course and you may just love the looks or performance of the trinado and the design elements it brings to the table. I'm not bagging it out by the way, for the narrow niche the design occupies it is quite elegant solution but I just cant see the benefits for most people.
    I would think that the B24 would run away and hide from a Tremelino it has more waterline a better hullshape, float design etc. Anyone done any direct comparisons?
    Nothing against the Bucc24 but I'd consider having a look at the Wavelength 780 for cruising by Bob Forster it's a very neatly designed unit and is foldable for trailering it's a viable homebuild and is constructed from vertical strip planked ply and timber stringers. An offset centreboard allows good useable interior space.
    http://wavelengthmultihulls.com/
  15. cavalier mk2
    I'm not so sure about the speed Corely, it depends on the amas. With New Moon amas a Tremelino goes well past 20 knots. The Bucc submerges its amas before then.
