CheoyLee39
Junior Member
- Joined
- May 12, 2014
- Posts
- 21
- Reaction score
- Location
- Cairns
Thank you for all that solid advice.
Yes, approx 3-4 'millimeters', I essentially just stripped the old varnish off with 80 grit, and am now using a finer grade for finishing. I do have several sanders, including a corner sander for those tricky areas.
I will follow the advice that pretty much everyone has given to thin down the first few coats, sounds reasonable. As there are 6 separate areas, forward walk in walk in storage and workbenches, midships Saloon/Galley, port side double berth, starboard side companionway/berth, and main berth/stern, I am tackling them separately now, as I am also going to complete the fixtures/fittings/trim, also all wood. I do think doing such a large amount of restorative work is best tackled that way as so much sanding may very quickly become tedious.
I also need to fill in a multitude of screw holes, and then re-screw some of the planks, for some reason a previous owner used several different sized screws, so some are very ill fitting. I do like uniformity.
So I'm off to purchase some wood filler this morning.
I will try and post a few pics this evening
Cheers
Cheers
