Bravo&torgue
Discussion in 'Sterndrives' started by costasgr, Sep 3, 2006.
  1. costasgr
    costasgr Junior Member
    Does any of you know how mutch torgue the bravo drives can handle?
    i have all ready blown three of them
    The boat is equiped with yanmar 315 hp 600 lb ft
    thank you
  2. marshmat
    marshmat Senior Member
    Which Bravo? (The I, II and III series are different internals, and the XR is different again).
    Have you been abusing the drive? Such as running it while in the tilted-up position? (This shreds the driveshaft joints and puts a lot of stress on the bearings.) If not, I wouldn't expect much trouble unless you have put the wrong drive on. I would normally expect to see a II series if the boat is a big cruiser, or an XR if it's a fast boat, with this motor. I seem to recall the stock B-I warranty is for up to 500 hp 500 ft.lb, but don't quote me on that as I don't know for sure.
  3. costasgr
    Bravo specs
    Thank you for the reply
    It is a bravo 3 on a 9000 lb inflatable and it is been blown in 280 hr.
    The think is that i can't find anywere specs about bravos writing for the torque that they can handle.
  4. Eduardo Sanchez
    Eduardo Sanchez New Member
    In Bam marine website you ll find that the new Bravo X (stronger gears) is rated at 525 lbft
  5. costasgr
    600 lb ft torque
    Thanks Eduardo
    The yanmar 315 produces 600 lb-ft at 2800 rpm
    IT makes me wonder why the bravo official specs dont mention anything about the torque that the drives can handle.
    Anyway, looking for an arnesson , there is one that replaces bravos without moving the engine.
    what do you think about it ?
    thank you for the reply
