I am planning a 26 foot aluminum pilothouse with a 300 mercury 4 stroke and 20hp kicker motor. Both motors will be mounted on 6 inch setback jackplates and tied together with a tie bar. So I can reduce the center to center distance.
I am modifying a stock plan from a boatbuilder to try and fit my needs better. I made the following changes.
Raise interior cabin height by approximately 5 inches, I did this by increasing hull depth as opposed to raising the cabin further over the deck.
Extended the length of the cabin by approximately 2 feet.
Moved the walkway in the cabin to one side to create more comfortable seating on the port side.
Changed the cockpit to fish better by adding a Baitwell
Flat gunnels to mount downriggers and rod holders to a track system
Removed rails
Modified the location of mooring cleats
Modified the swim platforms to accommodate the two motors
Modified the hull to be less tender at rest and still be able to ride nicely in rough seas.
The following are my best attempt at cross sectional representations of the hull design and some other changes that I am trying to make.
Removed rails
