Boxy Fisher Catamaran
Discussion in 'Multihulls' started by Fanie, Mar 11, 2009.
  1. hoytedow
    Patience is definitely virtue.
  2. Fanie
    Fanie Fanie
    I've made two more jigs today.
    The first (orange) is where the glass is wound on that will enclose the pin housings and connect them to the beams.
    The black PE strip is so the glass can be cut through and taken off the jig to go to the beams. The circumference was made the right length.
    The second is the plastic pipe on the right. The glass wound on it gets wound back around the beams to hold the above mentioned glass in position.
    It will eliminate rhe risk of delamination.
    The driving end of the jig 'holder'. The reason for adding the thickened part is so I won't have to adjust the motor position each time a different jig is added.
    The trailing end. The thickened part is loose over the pipe and can be removed to take the different jigs off.
    The hull jig's ends. The disk with screws will be welded on the one pipe end and the sprocket just gets fitted and bolted ( or is it nutted ?) in place.
    It is still too hot to do the beam ends. Since there are two sets of glass that goes on the pin housings and the beam ends, I don't want to risk the resin to start kicking too early.
      File size:
      153.1 KB
      File size:
      114.6 KB
      File size:
      159.5 KB
      File size:
      149.9 KB
  3. masalai
    masalai masalai
    busy little bloke?, now go whiten your beard for your part as santa-claws in the pirates panto...
    Now go borrow some money from this mafia non-authorised operator
    - - - - - - SPAM, just in - - an opportunity too good to miss :eek:
    "Unity Loan Investment Company is offering outs loans to the public with a very
    low rate of 0.5%. We offer out personal and business loans.Are you in
    debt and you need an urgent loan? Do you need a real estate loan? Do you need
    secured or unsecured loan?Need financing but don't know how to go
    about securing a loan? Contact us for help.Financing shouldn't be a mystery.We
    would love to fund projects at hand and offer personal loans as well to you,
    your firm/partners and clients. A loan process can be completed within a space
    of one week provided terms of loan contract is
    agreed upon. look no further contact UNITY INVESTMENT SOLUTIONS COMPANY
    today on. - - - - Email: uloan60@gmail.com
    Name: _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ :eek:
    Amount Needed: _ _ _
    Home Address: _ _ _ _ _ _ _ _ _ _ _ _
    Country: _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
    Mobile/personal Phone Number: _ _ _ _ _ _ _ _ _ _ _ _
    Home phone Number: _ _ _ _ _ _ _ _ _ _ _ _
    Purpose: _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ Yours in Service, - - Dr. Paul Smith "
  4. Fanie
    Fanie Fanie
    Eh Mas, what's that all about ??
    In the mean time, I'm making a counter for the jig. This will make it easier to achieve the required amount of layers when assembling the beams.
    Took me half the afternoon to find the parts in this unorganised workshop of mine. In the end the stuff was found, sitting on my desk :eek:
    I will decide later how fancy it should be, I have to adjust the software that I wrote before for the timer in pic 2 that I made for using when doing the glassing.
    The time can be preset, in this case 15 min. It gives a beep every minute and on 15 minutes an alarm. You'll be surprised to see how long some things take to do. The timer just keeps one's attention and reminds you of the time worked.
    I restart the timer each time new resin is mixed.
  5. Fanie
    Fanie Fanie
    The next jig would be for glassing the hulls. This is a fairly big jig, 11m in total and 600mm diameter.
    Then a jig for the masts, not as big but long. I will have to make some kind of support system for it so the center doesn't sag.
  6. Itchy&Scratchy
    Likes: 3, Points: 0, Legacy Rep: 117
    Itchy&Scratchy Senior Member
    Hey Fanie
    just found this thread, looking good:D
    please keep posting more pics as you go along, nice to see good old ('boer maak n plan' inventions)- I might have to pay you a licensing fee to make a roller like yours when Im finally back in Sa...... ha, ha.:p :D
    groete
    Justin
  7. Fanie
    Fanie Fanie
    Hi Justin,
    You first have to come back :D
    All just goes frustrating slow, mostly a shortage of hands here, but yes, it works quite well and very fast.
    I have in the meantime decided to build myself a smaller cat also, probably 8 or 9 meters, also trailable but more like a daysailer.
    4 5 c, don't tell the wife, it will ruin 2010 and on into eternity for sure :D
  8. Itchy&Scratchy
    Hey Fanie
    Ja for the moment Im stuck over here still, Ive just come back from SA about two weeks ago, I went to take my wife and 8 month old boy back home, now Ive just got to make enough dosh to get my container home with house stuff, tools etc and then , some more dosh for my dogs and finally a bit more dosh to get me home. Hoping to get back by around end March and I can start again.
    Ill be a bit far away from you guys down in PE(actually Im not sure where you are-where are you???) and where are Manie and Wynand as wel?? but of course if ever you are in PE , w'ell have to get to gether and go for a drink or two.;) ;)
    regards
    Justin
  9. Fanie
    Fanie Fanie
    Pretoria, Centurion. Just around the corner from PE :D
    You can come back as long as you won't vote for the anc again ;)
    Manie is about 5k's from me if that much, Wynand is in Welkom in the Free State. He says he likes his Free State Hamburgers - twee stukke stywe pap met slap pap in die middel ;)
  10. Itchy&Scratchy
    What do you mean vote again,
    The day I vote for those fokken swart bliksems.....:p
    Oh well I suppose ill have to get used to the old Philamon again.
    I ll come visit you if Im ever up that way.
    J
  11. Fanie
    Fanie Fanie
    Lets hope it's on the boat ;)
  12. bill broome
    Likes: 2, Points: 0, Legacy Rep: 48
    bill broome Senior Member
    i greatly admire the optimism here, many possibilities for failure. those folding beams are a serious bit of engineering.
    best of luck, eagerly awaiting news.
  13. Fanie
    Fanie Fanie
    Hi Bill,
    I've wrestled with them more than you can know, but I finally got it figgered. My fiberglass guy concurred, they will be good to go.
  14. outside the box
    outside the box Previous Member
    Keep up the good work
    Just a couple of shots of the same sort of idea you have that worked very well from Roger Simpson's design board from Australia, built in aluminium. The owner relayed to me that it was quite stiff and sailed well with just a little movement in the hinge's.
    Keep up the good work.
    Regards
    Craig
    NZ
  15. Fanie
    Fanie Fanie
    Hi outside the box,
    Thanks. I will gladly look at what others did. I have considered SS also, but doesn't matter which way there was always some drawback between weight, strength and cost. I have seriously considered SS, and it would bave been easier to do since the parts can all be laser cut and welded, but the weight...
    I think folding boats are a good idea, and I'm surprised there aren't more builders that does this kind of thing. Most people would like more space than the common power boat and doesn't want to leave it in a marina. We fish different places so obviously it must be trailable amongst other things.
