boxed floatation foam
Discussion in 'Materials' started by firstflight, Dec 10, 2001.
  1. firstflight
    firstflight New Member
    Can anyone tell me the names of manufactures of block floatation foam that is compatable with polyester resins and has gasoline resistance. I am building a 72ft.6inch trimarand which the foam will be both mold and floatation support of the hulls. I appreciate any help.
    Bill
  2. Scott
    Scott Junior Member
    If you have a large budget and the foam is going to stay as part of the hull, the stuff to use would be either an Airex or lightweight Klegecell foam. But these are both pretty expensive.
    Divinycell- http://www.diabgroup.com/ or
    Klegecell - http://www.diabgroup.com/
    Herex - http://www.alusuisse-airex.com/products/e/100/130_e.htm or http://www.baltek.com/airlite_herex.html
    or Corecell.
    In general if the foam has to stand up to polyester resin and gasoline polystyrenes are out and you are looking for a urethane foam.
  3. Scott
    Scott Junior Member
  4. Scott
    Scott Junior Member
    And as far as cheaper sources, Polyurethane typically comes in 4’ by 8’ by x number of feet blocks called ‘buns’ I believe. They will slice it to the thickness you want at a cost of around $15 per inch of thickness in a 4' x 8' sheet. Sign companies use sheets up to a few inches thick. For thicker you would want to look for a commercial insulation or refrigeration company or contractor.
  5. keith
    keith New Member
    You can use polyurethane foam in sit. material, but that would mean creating a mould for the foam. The other way would be to buy the block form, or create a block your self and carve it. the urethane is petrol resistant. Buying the foam in two pack is not that expensive and you can designate the density and characteristics.
