Bow Shape, Drag
Discussion in 'Boat Design' started by Bern, Sep 20, 2004.
  1. Bern
    Bern Junior Member
    What shape bow has the least amount of drag, Jon boat style, Model, or ???? How much difference will there be, significant? (Beam of 7 ½ feet, Length of 18 feet, Draft 5 inches, Speed max. of 7 MPH, Chine 90 degree) Looking for minimum drag. Thanks for any and all advice/comments.
  2. jehardiman
    Likes: 1,167, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    From the statement "Jon boat style" I assurme you're just making a small jon boat/box barge. No bow shape will help that length, breadth, depth, and chine shape. Just rake it 30-45 degrees above horizontal like a barge and snub it off to a convient depth for the bow transom. You don't want a large overhang so you can use the ends.
  3. Bern
    Bern Junior Member
    Left out info.
    Oops, Make that a flat bottom boat with a few skegs.
  4. jehardiman
    Well what is it? A unpowered shanty boat to be towed/pushed? A jon boat to be motored in a protected area? A a high performance sailing scow? A 90 degree chine is a poor hull form and a L/B of 2.5 ain't too hot either!
