Bottom Paint
Discussion in 'Materials' started by linwoodhardy, Oct 11, 2015.
  1. linwoodhardy
    linwoodhardy big coco
    ? Im building a 19 meter Cat and want to bottom paint now before turning the hulls. Does bottom paint loose its properties or die? after applied if not in the water for up to maybe 1- 1/2 years before launching?
    Thanks for any knowledge.
    Linwood Hardy
    Likes: 2,417, Points: 123, Legacy Rep: 2031
    Most modern ablative paints can be left on for long periods.
  3. linwoodhardy
    Thanks I will proceed Linwood
  4. PAR
    18 months is a long time to ask antifouling to wait. These paint generally don't have good UV resistance, so by the time you do launch her, you might have just a few months of service from the paint. It will also be badly streaked (weather) in this time frame, further decreasing its effectiveness. Consider painting under the supports currently, then waiting until much closer to launch day to finish up, in the places you can reach.
