rxcomposite
Senior Member
- Joined
- Jan 16, 2005
- Messages
- 2,865
- Reaction score
- 682
- Location
- Philippines
It seems you conversion is wrong. 0.001" = .0254 mm, thus .005"= 0.127 mm.
Thus if the standard bore is 98.425 mm, +98.552 mm (+0.005"), -98.299 mm (-0.005") it should be fine.
Like I said, for a quick check, try to fit the rings and see if the gaps are within specs. If there is a gap, it means your measuring instrument is fine and everything should fit as planned. If the gap is larger than spec'ed, then worry. Something is wrong.
For small block engine, it is usually rated as (in Imperial) Standard or Zero, +1 (+0.010"), +2(+0.02"), +3(+0.030), +4(+0.040"). If it is within +-0.005" or 5 mils (+-0.127 mm), then it is within tolerance and still usable. Anything above standard is an overbore.
