Hi guys, thx for all the feedback. will make short question longer...
however still try to be short...
I had myself a Fletcher boat for the price of nothing...
I decided to strip it completely down.
now i am starting to rebuild and that is where the engine come in the play also...
altough the previous owner said they had dome some work on the engine i want to be sure of the state of that engine
so i did put new head gasket because i removed the valve head to (i opened the engine to see how it looks inside)
lets say it looked ok could spin it by hand ...
i closed the engine and built it up again....
put in oil and primed it till i had oilpressure
cranked it and it ran in a few moments after fuel got thru the lines....
after running i tested compression that is where i noticed some problems...
loss of compression on 3 cyl.
so i opened the little beast:
checked for leaks by pouring oil on the pistons and by blowing air into the inlet outlet of the valve head.
this showed me leaks on most of them some minor some bigger. I polished the valves in their seats with some drill and compound with some positive result at the end.
No more leaks....
As concerns the cylinders i had one where the oil dissapeared...
thats where i decide to take out the pistons.
in short most look ok but one has oil rings completely seized on the piston.... unable to remove them, heating soaking tapping ... no help....
so there is tthe moment i say i need new piston(s) and rings
So to besure of the size and be sure the bore wasn't oversized yet i started measure and that is where my question came from.
I find smaller bore diameter than the manufacturer specs which does'n sound normal to me.
should be 3.875 ±0.005 in my case i prefer mm 98.425
I measure 98.35 - 98.40 so this makes me confused with the specs... temp where engine is is 18°C
is there a reason for this?
I also measure the gap of the segment rings: 0.40-0.45mm that seems correct
I had a small picture with some readings from my compression testing and some coded text
