Jeff in Boston
Senior Member
- Joined
- Sep 7, 2020
- Messages
- 110
- Reaction score
- 31
- Location
- Boston
I'm replacing a cast iron keel with a short steel keel as part of my conversion of a Pearson 26 One Design to a slow solar cruiser. The keel with be 3" or 4" thick plate with bottom tapped bolt holes. The closed tapped holes will allow me to remove / inspect / replace bolts one by one while the boat is in the water.
I know I should avoid stainless below the waterline. That seems to leave me with bronze or hot dipped galvanized bolts (5/8" -11) I'm thinking the cost of the bronze will roughly equal the cost of an oversize tap for the HDG bolts.
The strength of the bronze is certainly sufficient.
Does any one have any suggestions on which I pick? I'm thinking bronze.
