Boat transom design
Discussion in 'Powerboats' started by Kastally80, Jan 20, 2018.
  1. TANSL
    Likes: 232, Points: 73, Legacy Rep: 300
    I am convinced that yes, it is more, I think that the fund that you propose is going to generate "3 different waves" that will interfere with each other. The more irregular the bottom, the more irregular the wake will be and the more energy will be consumed in creating it. Everything you spend to remove the water will revert to a loss of speed. IMO.
  2. fallguy
    Likes: 221, Points: 63, Legacy Rep: 10
    fallguy Senior Member
    TANSL - you know I am not an expert, but is it possible the secondary waves created will have a dampening effect? I would look at this design a bit like a tri-hull or cathedral hull or tunnel hull...don't those result in less wake than say a deep vee?
  3. TANSL
    I think that stern will move much more water than a normal V stern. But what the OP wants is to improve the shape of the wake. I do not know what it is to improve the shape, because I do not know what it intends to do with that wake, but in any case, the wake will be much more turbulent and irregular.
  4. fallguy
    I won't answer for the OP, but I was assuming he wants a bigger wake. The idea that somehow a chaotic wake would be introduced from a symmetric hull gives me pause...but I really have no idea.
  5. jorgepease
    Likes: 47, Points: 48, Legacy Rep: 75
    jorgepease Senior Member
    These notched transoms are often used with flats boats in conjunction with a tunnel. The tunnel lifts the water up and the notch helps keep the water around the prop of the elevated outboard. In this case, if I understand correctly, the prop is still below the bottom of the boat and I don't think it's going to give you any better wake. One thing that is happening is you have reduced the planing area, you might throw off the balance and since the hull extends behind the motor you might not get the bow up at the correct angle. Pods for example are raked up to avoid that happening.
  6. Wayne Grabow
    Likes: 17, Points: 18, Legacy Rep: 297
    Wayne Grabow Senior Member
    You are, of course, correct. I forgot to include that the overall length of the boat, including OB, was limited for storage reasons.
  7. Rurudyne
    Likes: 33, Points: 48, Legacy Rep: 155
    Rurudyne Senior Member
    Just a thought: those aft projecting bits look like a dandy place to mount some adjustable trim tabs
  8. Kastally80
    Kastally80 Chargui Yacht Design
    Yes correct Rurudyne ! there will be a classic folding trim tabs, as shown in the photo, or Humphree interceptors.
