Horton HCCI
Senior Member
- Joined
- Aug 14, 2021
- Messages
- 121
- Reaction score
- 15
- Location
- Denver, CO, USA
Why does one need big twisting stiffness? My thought is, make it as soggy as possible. Offer little or no resistance. Roll away. What's it hurt? No one says you have to keep the float flat. It can roll up 15, 30, 45 degrees. If you picked the float up, you could twist it whatever--45 degrees up, 45 degrees back, 45 degrees one side, then the other, all combinations. Just no yaw. Otherwise, like an ankle joint. There are three other points, spread out a loooong ways, to keep the vessel stable overall. What one joint is doing doesn't really matter, as long as it isn't digging in or sinking. It can bob up and down and rotate around as dictated by the buffeting of whatever bumpy water it's encountering locally.Weakest point of your design is one point joint connection .
Dragged and pulled swingarms can be done , wide apart , stiff and light double swingarms .
One point attachment of the float is more chalennging:
-point of anchor need to be tested
-you need specific elastokinematics of joint
-you need big twisting stiffeness.
Why double swingarms? Maybe I don't understand what you mean. If we're just talking separation in, um, planform, the proposal is 6061 aluminum channel, 2" wide base (web) separating 1" legs (flanges) on either side. Do the legs count as "double swingarms?" And the 2" web the "frame?" It's not much, but I contend it should be plenty to resist sag and twist given the loads it should be subjected to. I could use separate, deeper arms, maybe each a channel, and bolt on cross members to separate, or use rectangular tube. But do I need to? The thing is on the order of a bicycle, after all. Swingarms are like chainstays, and those weigh a few ounces each. Human-powered, pretty much straight line. No thrust to speak of, total sprung weight for the vessel under 260 lbs, including 220-lb pilot. Unsprung weight around 15 lbs (all four floats and their attachments). Light weight and simplicity is paramount. An ATV might weigh 700 lbs, this thing should weigh no more than 45. No steel. Mostly Coroplast monocoque for floats and fuselage, carbon fiber and/or fiberglass tubes for support booms. The overall boat is 11.5 ft wide and 13.5 ft LOA. Draw a box between the anchor points on the four floats, it's about ten feet long and nine feet wide. Fuselage 10 ft long, 2 ft wide. For a single-person boat, pretty long, outrageously wide, ultra-low power and slow (15-20 knots peak) and ultralight. If that helps conceptualize. More strength and separation would be appropriate for more weight and power, but I contend not needed (or wanted) here. I could use 1x3 channel, but it's twice the weight (and cost).
Again, I am not very adept at building, so anything complicated is not gonna happen, but there seems to be an advantage to simplicity in terms of promoting adoption, at least for a simple human-powered incarnation. And in all cases, the fewer joints you have exposed to the water, the better. And keeping the transverse support arm high and rigid gets it out of the water and lets the floats pivot and roll underneath it. A wishbone or parallelogram would get in the way of that. This keeps the support beam (rigid stub arms) high but keeps the fuselage slung relatively low.
Does one need to let the support arm pivot, like Nauti-craft? Why? Swingarm lets one float rise up and down with respect to the opposite float, and free roll relieves any torsion forces on float itself and on the vessel overall. I might have 6" travel at the ends of the arms. Water itself , and buoyancy, provides some "give" (and is all the "suspension" most boats have). The thing is super-floaty--4 floats add up to 1.5 times the footprint and rest buoyancy of a big SUP, around 1.5" draft. At rest, that is-- more like 1/2" draft on plane, assuming it planes.
What I'm most worried about is fore and aft loads on the shocks, with that three-point triangle setup. I'm assuming they have quite a lot, and that a clever linkage would align the loads more vertically, so they aren't transmitted to the sides of the shocks' pistons. I considered sliding pillar suspension at one point, but side loads there would be terrible, I'd think, plus they'd require long travel shocks if you hung them way outboard as I plan. Hence the swingarms.
Can you give me a quick sketch of what you're proposing with "double swingarms?" Or a better way to reduce fore-and aft loads, assuming they're there, on the shocks?
