Boat painting questions....
Discussion in 'Fiberglass and Composite Boat Building' started by futuresweets-10, May 23, 2006.
  1. futuresweets-10
    futuresweets-10 Junior Member
    I am the paint specialist at the orellys here, the store I work at does not carry imron, but the closest store to us does.
  2. fiberglass jack
    Likes: 16, Points: 0, Legacy Rep: 95
    fiberglass jack Senior Member
    your lucky that your only painting the topside of the hull you should be ok, painting a car is a breese compared to a boat try painting the cockpit or the deck its like spraying a floor a car is easy its right in front of you . i have seen many good auto painters say they can paint anything thats till they jump on a boat so take care and enjoy the challange
  3. edrhathaway
    edrhathaway New Member
    boat paint
    i just recently painted (for the first time - never sprayed before except from those little cans) and it wasn't too bad.
    Project: 21ft cuddy with Springfield engine bracket and engine
    Materials: Brightside by Interlux (1 pt poly)
    Found out AFTER i sprayed the first time about using a respiriator (I may die early death). Otherwise, that part went ok on second and later rounds.
    I used a cheapo sprayer (conventional). Sprayed about about 40 PSI. Spraying went very well. Have to resist the desire to spray heavy. At least with this paint, it doesn't dry very well if heavily coated. Best 2 use multiple coats. It levels quite well (in fact I'm told you can roll and tip it).
    I think if I knew more about sprayers and techniques it may have gone even better. But honestly, I just saw a boat sprayed at my boat yard by a "professional" and my stuff looks better.
    Now I didn't spray the inside (yet), but just the outside was a breeze...not hard, went on well, no primer, just 320 grit sanded the gel and made minor repairs as needed.
    Ed
  4. eyes
    eyes Junior Member
    Why didn't you use 120 grit. I have always seen people and myself sanding gelcoat with 120 grit to remove ALL WAX and imperfections. If you didn't the paint might peel over. I hope it doesn't.
  5. edrhathaway
    sanding with 120
    I didn't sand to remove wax, I sanded to smooth and get out the imperfections. Actually, i left out a step...I wiped the hull COMPLETELY several times with wax removal.
  6. eyes
    eyes Junior Member
    It's just that i didn't see the dewaxing step thats why i got a little nervous.
  7. bluethunder12
    bluethunder12 Junior Member
    also acetone work great for dewaxing and i am old fashion i say spray with gelcoat me myself i will not use a imron or any car paint scratches to easy and i have mixed my own colors using gelcoat and also me my self i use 80 grit then come back with 180 block that will really take out the imperfections goodluck
  8. edrhathaway
    I've never tried to spray gel, however, i'm told it's VERY difficult to prevent peeling (orange peel). I like the paint for the gloss you get and no powdery oxidation.
  9. eyes
    eyes Junior Member
    With paint you finish polishing and buffing the clear or the color. With gelcoat you can achieve high gloss too. You can sand it to 1200 grit, then polish and apply 3 coats of wax and buff, this will also prevent oxidation.
    You can achieve excelent result from any of the two methods, but we know you're familiar with car paint, so stick with it. Just make your job easier.
  10. craig mclean
    craig mclean Junior Member
    Glastron uses imron in production . however their dealers are having big problems getting repairs done, if your only painting a stripe why not use gel coat??
  11. craig mclean
    Prep 180, gel coat , let kick, spray pva, sand 180,220,320,400,600, buff with aggressive compoun,polsh
  12. jimslade
    Likes: 3, Points: 0, Legacy Rep: 27
    jimslade Senior Member
    THe most important step in painting is the primer. I only use a top quality epoxy primer. Any two part paint will work. I will never use Imron or Awlgrip. My life is important to me. I have been restoring cars professionally for 30 years. The primer that I use is called Glassheild, its made in Quebec Canada. They also make a quality topcoat.
  13. craig mclean
    I've been painting gel coat for ten years, and have only used sealer when painting plugs that have exposed wood or micro spheres. when the exsisting gel coat is usually around 20 mils I very rarely go through to the glass when preping. And if I do, and expose small air pockets i just use a glazing putty,sand then apply gel coat. If your boat is preped right the gel coat will have no problem sticking. 99/1 all preparation.
    1. Pjitty
    2. simostreca
    3. SRQseaside
    4. Abcie
    5. JP1
    6. Luke Rhoads
    7. Diyguy.
    8. Oscar1
    9. Alex Martin
    10. wendelin
