Boat identity
Discussion in 'Boat Design' started by Sam Gardner, Feb 23, 2021.
  1. Sam Gardner
    Likes: 1, Points: 3
    Sam Gardner New Member
    Hi, New to forum . I have a sailboat an a small runabout recently renovated but have no idea on their manufacturers. Perhaps someone can help with more info. The red fibreglass runabout is probably Swedish or Italian, it had a Crescent outboard originally, about 13'. The keelboat is 22' fibreglass with steel keel. Thanks for feedback.
    hoytedow likes this.
  2. bajansailor
    Likes: 1,722, Points: 113, Legacy Rep: 37
    bajansailor Marine Surveyor
    Welcome to the Forum Sam.
    Re the fibreglass keelboat, is the hull 'single skin' fibreglass, or does it have a core?
    If it is single skin, then the odds are that it came out of a mould, and hence might be a particular class or make.
    If it is cored, then it could be a 'one off' home built construction.
    Re the motor boat, that might be a 'one off' home designed / built boat as well.
    Maybe some folk on here will recognise these designs, and be able to give you some additional information about them.
  3. JSL
    JSL Senior Member
    a cored hull can be 'moulded'
    Sail boat looks like a pretty old boat - mid-60's
  4. Mr Efficiency
    The red one must go back to the 50's or early 60's, the sailboat looks like it would make a passable motor boat as well.
