Boat for HARD conditions
Discussion in 'Boat Design' started by Sudarikov, Apr 13, 2007.
  1. Sudarikov
    Sudarikov Junior Member
    Hello everybody
    First of all, sorry for my English. I have a project of a boat for hard climate conditions. My task is to design a boat for hunters, gold seekers, travelers etc… It has to be good on the river and in the sea. It will be used on frost and during hot summer. It will be used in Russia.
    Now, I am working with research. I have to understand what does designers and builders from Scandinavia, Canada, Alaska and other northern countries do.
    May be some one gives me any info about river-sea boats. I need any info and any pictures of boats used in such conditions.
    Thank you!
  2. mcollins07
    Likes: 11, Points: 0, Legacy Rep: 166
    mcollins07 Senior Member
    Requirements?
    What size do you envision?
    Is it trailerable? Can one or two men carry it?
    How will this boat be propelled? Does it have a motor, sails, yuhol?
  3. Sudarikov
    I think it will be near 20m. Possibly it will have two inside engines. It is for 6 men. 2 or 3 rooms with showers. Comfort level high
    but it is just a variant
  4. Bergalia
    Likes: 40, Points: 0, Legacy Rep: 254
    Bergalia Senior Member
    Sudarikov - contact your local fishing fleet manager. The big factory ships - we called them Klondikers in the west of Scotland - used to carry 'lifeboats' which sound ideal for your purpose. About 20 metres long, twin engined and the hulls were a complete 'wraparound' if you can imagine an elongated walnut shell. Weatherproof and as near storm proof as dammit. Saw them working in the Minches carrying provisions to the 'mother ships' from the mainland. Point is I believe at least two of the factory ships are now laid up somewhere in the Baltic. But good luck with your search.:)
  5. kach22i
    Likes: 111, Points: 63, Legacy Rep: 1222
    kach22i Architect
    If you are willing to think outside the box, how about a hovercraft?
    Russian:
    http://www.hovercraft.ru/argo_en.html
    American (Sevtec):
    http://www.amphibiousmarine.com/index.html
    Custom Sevtec hovercraft dredging for gold:
    http://members.aol.com/hovtec/hover/BUILDJ.html
    EDIT: In the North to Alaska article about the Sevtec they describe taking on 15 foot waves, close to shore without fear of bottoming out like a boat would. That and operating on ice and in shallow rivers is why I've offered and will continue to offer the subject of hovercaft as an alternate to be seriously considered by boaters everywhere.
  6. Sudarikov
    Interresting idea!!!
    How do u think, is it possible to make hovercraft comfortable? Are engins loud? What is the max light of them? Is it possible to make 2 flors? What is the max speed and the wight of way withot refilling?
  7. Sudarikov
    May be some one can give advice about SPECIAL parts for hard conditions? May be antifrost mechanism. Or dors for cold climate... etc
    I am very glad, friends to get your info! Thank you
  8. Sudarikov
    Bergalia, i did not exectly understand about "complete 'wraparound' if you can imagine an elongated walnut shell". It is interresting! Can you discuss more please?
  9. lazeyjack
    lazeyjack Guest
    Where are you Murmansk?
    you have your PM IM disabled
    Poka
  10. lazeyjack
    lazeyjack Guest
    i would build aluminum, quick to build, cold does not effect it, 4 inches sprayed polyurathane foam to hull, thick plates
    And here you have case for hamilton water jet, da!!
    what sped woulkd you liike to achieve, river sea?
  11. Sudarikov
    Privet, Jack, I'm from Moscow :) Hi everyone!
    Nice idea using alluminium. And what about construction elements? This is my diploma work. I am looking for bright ideas to use in my boat. I want to combine info of the boats for such condition.
    my boat is 14-15m, Rooms: 3+1, high comfort level, 2 engines. For hard climate. Hull possible alluminium :) May be it is a hovercraft.
    If you know any analogs show me please!!!
  12. Sudarikov
    DO some one know any ship yards of canada, alaska, finland etc. or yards which build boats for this countries? I would like to see what guys from there do
  13. monrosm@shrewsb
    monrosm@shrewsb Junior Member
    Lazeyjack, aluminium is a nice idea but could be lacking in strength and hardness on sea ice, why not substitute the aluminium for Duralumin, much stronger and harder, not much heavier, but does cost a little more.
  14. Sudarikov
    Hi gues!!!
    i made a model of my diploma ship!
    I need your advices! It is rood for a wile, but i work about this.
    Thank you!!!
      File size:
      13.7 KB
      File size:
      21.6 KB
      File size:
      20.2 KB
      File size:
      33.6 KB
      File size:
      20.8 KB
      File size:
      25.8 KB
      File size:
      33 KB
  15. Sudarikov
    TECHNICAL DATA
    Loa 17m (55 feet)
    Max beam 5m
    Passengers 6-8 people
    Cabins 3+1 or 4
    Boat can be drived by owner or by crew
    3 shower cabins
    Editional weight 1000 kilos to transport on aboard.
    Special conditions:
    Could move in the crushed ice
    Opening parts for hot and cold weather.
    Integrated raft or (&) jet ski
    Ability to tug
    Wraparound fender
    The front will open to let people go in and out anywhere
    Washing machine
    Fuel tank 2100 litres. Water tank 120 x 8 x 7 = 6730 liters (every person will consume about 120 liters per day. Needed for a week). Or 600 litres + water cleaning system
    Engines in board
    Desiel dose. Propeller
    Top speed 30-40 knots
    Build material
    Hull is made of steel. Superstructure is made with resistant polycarbonate (ploycarbonate is good for insulation because it does not conduct heat or cold very well) or fiber glass. Windows – double glass. Deck is made of teak.
    2 emergency life rafts one on each side
    Hull: flat bottom, or shallow v shape, or catamaran. Quite square. Its going to be good in rivers and OK at sea.
    Opening parts
    Back dors are sliding, opening parts of corpus are built in car design principes. Electricly sliding. Back part of boat has pod for raft. The front will open to let people go in and out anywhere
    Comfort level
    First variant - basicly spartanian
    Second variant - hi level of comfort
    Style
    Style is built from functions. Analog Hummer. Going to look military in shape.
    Range, how far will it need to go
    500 miles with about 1000 gallons
    Storage for food
    For a week
