Boat design with movable (up/down) prop shaft??
Discussion in 'Boat Design' started by Rollbar, Sep 23, 2018.
  1. Rollbar
    Likes: 1, Points: 3
    Rollbar Junior Member
    Do any of you know of a boat design that used a shaft connection (inboard) to a drive shaft to prop, that could be raised and lowered as needed and could be launched off a beach?
    Thanks,
  2. KJL38
    Likes: 13, Points: 18, Legacy Rep: 75
    KJL38 Senior Member
  3. Rollbar
    Likes: 1, Points: 3
  4. rwatson
    Likes: 341, Points: 83, Legacy Rep: 1749
    rwatson Senior Member
    Heres is a slightly improved version
    " Retracting Drive Unit
    The retracting drive unit in the 35 MKII is a little different from others that have been built. Where others have employed single or multiple constant-velocity joints to keep the angular velocity constant, we can use a simple universal or Cardan type joint. This works because the tail shaft is in alignment with the stub shaft coming from the gear when the unit is deployed. The universal joint also functions as the hinge point for the strut." Bieker Boats: Retracting Drive Unit http://biekerboats.blogspot.com/2012/11/retracting-drive-unit.html
    Rollbar likes this.
  5. rwatson
    Rollbar likes this.
  6. goodwilltoall
    Likes: 26, Points: 28, Legacy Rep: 31
    goodwilltoall Senior Member
    With all the complications of a lifting prop, my conclusion is that a tunnel hull prop is a much better idea. The rnli and other north european SAR organizations use it. Dave Gerr is a modern day advocate for it although I would like to see others using/designing it for low power displacement efficiency.
    Rollbar likes this.
  7. Rollbar
    Likes: 1, Points: 3
    Thank you, awesome design
  8. Rollbar
    Likes: 1, Points: 3
    Yes agreed, but ,,, :)
  9. alan craig
    Likes: 112, Points: 53, Legacy Rep: 14
    alan craig Senior Member
    Rollbar likes this.
  10. OCB
    Likes: 5, Points: 18, Legacy Rep: 10
    OCB Senior Member
    I only see sail boats with retractable drives. What size boat, motor and shaft are are you thinking of using? I'm working on inboard boat drive that has the pivot at the transom. I design it for small inboard boats with tiller steering.
    OCB
    Rollbar likes this.
  11. Rollbar
    Likes: 1, Points: 3
  12. JSL
    JSL Senior Member
    And, what about the rudder?
    Another reason why Mr. Evinrude invented the outboard motor.
  13. Waterwitch
    Likes: 30, Points: 28, Legacy Rep: 20
    Waterwitch Senior Member
    Rollbar likes this.
  14. OCB
    OCB Senior Member
    ESA propulsion
    Rollbar likes this.
  15. JSL
    JSL Senior Member
    If you can manage without a shaft, How about a
    (a) sterndrive (inboard outboard)
    (b)a surface drive (Arneson).
    Efficient, Proven, & 'off the shelf''. Can be direct or remote mount with a jack-shaft.
    Rollbar likes this.
