1. The Marketplace Forums can be useful for members who know one another well from forum discussions and offline communications and wish to post boatbuilding tools, drafting tools, molds and tooling, and other professional equipment for sale or trade. However, caution and good judgement should always be used. Especially when considering any business with anyone not already well known to you and trusted, due diligence must be used to confirm details and identity and be sure the transaction is safe before any money or property changes hands. Always use good judgement and perform due dilligence and follow these guidelines.
Boat Building Material-Fiberglass Chopped Strand Mat
Discussion in 'Marketplace' started by chinaweibo, Jan 24, 2016.
  1. chinaweibo
    chinaweibo Zccyfiberglass
    Fiberglass Chopped strand mat is a kind of glass fiber non-woven reinforcing material by chopping continuous strands into chopped strands of certain length (50mm) and uniformly in combination with polyester binder in powder or in emulsion form.
    Chopped strand mat is suitable for application by hand lay-up, reinforce and machine FRP molding, such as interior decoration of vehicles, boat hulls, sanitary ware, anticorrosive pipes, tanks, building materials, tables, chairs and all kinds of composite FRP products.
    E-glass Fiberglass Chopped Strand Mat (CSM) Characteristics:
    Even distributing; same character; good wet-out in resins; good overlay capability; excellent mechanical physical and chemical capability.
  2. TANSL
    Likes: 850, Points: 123, Legacy Rep: 300
    Fiberglass Chopped strand mat is a procedure not accepted by some administrations for the construction of the hulls of ships. That is due mainly to the difficulty of getting the mechanical properties of the final product are uniform, they can be quantified and beyond the minimum required.
  3. jonboatlover
    jonboatlover New Member
    Do you have a shop in US?
  4. Landlubber
    Landlubber Senior Member
    I have contacted you direct from your web site, thanks for the introduction to your company. Ta, John
  5. FAST FRED
    FAST FRED Senior Member
    Most of the problems with CSM can be solved easily by weighing the CSM ,
    and then mixing the correct weight of resin and doing a uniform application.
