scotch&water
Junior Member
- Joined
- Jul 25, 2009
- Posts
- 70
- Reaction score
- Location
- Great Falls Mt. USA
One more note, this style of boat have a reputation for being tail draggers - too much weight in the back. I added perhaps 200Lbs with my install.
Note: This feature may not be available in some browsers.
This is putting extra load on the propeller blading. On top of that, you replaced one 20 inch diameter propeller with two 16 inch (??) dia;s in tandem. The problem is that the 16" set must produce the same thrust as the 20" prop, but with only 64 % of the disc area, which leads to a much higher sensitivity for cavitation and ventilation.One more note, this style of boat have a reputation for being tail draggers - too much weight in the back. I added perhaps 200Lbs with my install.
The Bravo I and III drives swing maximum 16", and the Bravo II takes 20" propellers. Standard Mercruiser B III series start with 20" pitch, haveing 16" (fwd) + 14 3/8" (aft). The 26" pitch set is 15 1/4" + 14" diameters. The pitch/dia ratio for the Hills(?) propellers used here is unknown to me, but should follow the same pattern as the originals. Possible difference is SMALLER diameters due to four blades instead of three, so even worse for the operation.The drive is running just 16" diameter props, do you say ? This is the wrong drive for the boat, if that is the case.
Would you please explain to us how the rpm increase you suggest would improve cavitation performance?The increase in propeller RPM would increase your speed. It would also load the engine more and prevent it from over-revving.
Baekmo:
"The length of the Bravo II and Bravo II are the same. Therefore, if it didn't ventilate before, it should not now."
"As far as cavitation, dual props will have less loading. If it did not cavitate before, there is no reason to suspect it does now with lower blade loading."
"Increasing RPMs will increase speed without any need for low pitch propellers."
"To maintain the same propeller pitch as before, the shaft needs to turn at the same speed as before. Therefore, the gear ratio for an engine that generates maximum power at lower RPMs needs to be reduced not increased, to maintain the same propeller RPM."
