mrintense
"Clipper"
- Joined
- Jul 3, 2012
- Posts
- 23
- Reaction score
- Location
- Austin, Texas
First off, before I say anything, please forgive me if I say something ignorant. I am building a 21 foot wooden cabin cruiser (I have another posting her somewhere on that) and have reached the stage of designing and building the sole under structure (in bilge area).
I am trying to account for all items that may be placed in this area before I get too far into the construction of the structure so that I do not build myself into a corner. I have accounted for bilge pumps and associated fittings, encapsulation of all wood, and limber holes.
I understand the need for bilge blower systems on inboard boats, however I am not sure about outboards. In my case, there will be two fuel tanks mounted in the sides of the boat between two of the frames. These tanks will be located above the sole at a point just aft of and outside the cabin. The cabin is an open design with the forward windows capable of being opened, so ventilation of the cabin is not an issue.
I have no idea what a bilge ventilation system should look like other than pictures I've seen of engine boxes with ventilation blowers built in. It's been difficult finding material that adequately explains this.
So the questions are: Do I need to have blowers mounted in some way so that they will ventilate the area below the sole? Is it necessary to run ducting under the floor between frames (necessitating drilling holes in the frames)?
Here is a picture of where I am at as of today. This internal structure (except for the boat frames) is temporary tooling to aid in the final design.
Note that my boat has frames below the sole and the floor will be constant height, so each section between the frames will be separated from the next with only small limber holes allowing passage of water aft.
In the photo I have crudely drawn representations of fore and aft supports for the sole so if I were to use this idea, the under sole area would be further compartmentalized. Basically I am looking for a bit of guidance here before I get too far into this phase of the build.
