Bilge Pump Problem
Discussion in 'Boat Design' started by steve123, Feb 2, 2015.
  1. steve123
    Likes: 2, Points: 0, Legacy Rep: 20
    steve123 Junior Member
    Hi,
    Anyone come across this problem...Large Bilge pump self priming centrafugal runs fine until its actually pumping water then it vibrates like hell !!!!
    Likes: 2,044, Points: 123, Legacy Rep: 2031
    It could be a number of things. For example, it can be sucking air, the impeller may be loose, worn bearings.
  3. steve123
    There are 8 of these pumps on the boat, they are all brand new and 7 have this problem.
  4. gonzo
    What does the manufacturer say? I assume there is some kind of warranty.
  5. michael pierzga
    michael pierzga Senior Member
    Sounds like air. Some vane segments are full of water , some vanes full of air .
  6. gwboats
    Likes: 13, Points: 28, Legacy Rep: 77
    gwboats Naval Architect
    Bilge Pumps
    If it is not a motor problem (rotor balance, electrical phase balance) then my guess is cavitation. Do the pumps have any sharp bends just before the inlet - these can cause flow problems. Best to fit a straight run into the pump of say length = to 8 to 10 pipe diameters.
    Cheers
  7. Poida
    Likes: 51, Points: 48, Legacy Rep: 497
    Poida Senior Member
    Post a pic of the set up.
    Poida
  8. PAR
    What type of piping, how much "lift", pipe diameter?
  9. Kailani
    Likes: 8, Points: 18, Legacy Rep: 59
    Kailani Senior Member
    You didn't say what brand the bilge pumps are.
  10. kapnD
    Likes: 482, Points: 83, Legacy Rep: 40
    kapnD Senior Member
    Eight large bilge pumps?
    I'd say your problem is not with the pumps, but with the leaks in the hull!
    I have seen shaft corrosion issues on some submersible pumps that caused weakening and resulted in severe vibration, eventually breaking clear off.
    If they are controlled by a float switch, the "off" level may need to be adjusted so that it shuts off before it sucks air, which could cause vibration.
