Bilge keel conversion a la Westerly Centaur
Discussion in 'Boat Design' started by Podowitz, Mar 18, 2017.
  1. Podowitz
    Podowitz New Member
    I sail in pretty skinny waters. A friend has a Pearson 30 that's been on the hard for a number of years. Motor gone but bracket on the stern. No blisters, no soft spots. Yard offered to take over the boat for the keel salvage and cut the boat up. I was thinking of taking over the boat, surrendering the keel to the yard, and outfitting the boat with a shallower pair of bilge keels. Please share your thoughts on how to accomplish, No naysayers please; I already know it's a little crazy.
    Likes: 2,293, Points: 123, Legacy Rep: 2031
    If you give the keel away, you'll have to go and buy the equivalent amount of metal to make the new keels. The plan makes no sense.
  3. keith66
    Likes: 31, Points: 28, Legacy Rep: 168
    keith66 Senior Member
    Buy a shallow draft boat to start with & save yourself a world of agravation.
    Westerly centaurs draw about 3ft 6", plenty for sale over here for not a lot of money. They do suffer from the keels falling off though.
    If you insist on doing it it is possible. A local yachtsman took a Hunter Sonata fin keeler, removed the deep fin keel & fitted bilge keels to her, he did a lot of research & designed them properly & did a splendid job. She sails very well & he has put a lot of miles on her.
    The fact remains it is never ever going to be an economic proposition.
  4. Angélique
    Hi Podowitz, if ever doing it . . :eek:
    Then better go for less wetted surface, so less hull resistance, plus a lower center of gravity for the same draft, so enhanced stability, compared to the traditional Westerly Centaur type of bilge keels, and add NACA profile bilge keels with bulbs à la the RM 880 . . .
    You probably also have to adapt the Pearson 30 rudder to the new draft as well I guess . . :idea:
    And while at it, best also make a outboard well instead of the stern bracket ---> Atom Voyages ---> The Inside Outboard.
    Or buy a boat that suits you as it is, and go sailing right away . . . :idea:
  5. Angélique
    There's a 26' steel bilge keeler build in the threads Never say never and in 25.6ft Gaff Cruiser under way Quote: Pics = Post #1, Text = Post #4
    Note that the previous posted NACA profile bilge keels need to be toed in and canted outwards as in the above quote I think, but the bulbs centerline could be best flush with the boat's centerline and the waterline I believe, to have least resistance.
    Also note that the Pearson 30 has an encapsulated fin keel, so extra bottom repair is needed there when the fin keel is removed, and the bilge keel attachments through the hull need internal hull reinforcements, also the bilge keels and the adapted rudder with the new draft need to be firm enough to stand on when drying out, and take some boat jumps by waves when just more or less standing.
    Please keep us informed of your plans, and if you decided to start, the progress of project, and eventually the sailing results . . :idea:
    Good Luck !
  6. Stumble
    Stumble Senior Member
    Just buy a shallow draft boat. Trying to retrofit bilge keels would be an absolute distaster unless you spend more on an engineer to figure out the local reinforment needed to support the loads.
    You could probably buy a mid size cat for the conversion costs.
  7. keith66
    Never mind spending out on an engineer to calculate loads. Westerly yachts were professionally designed & sold like hot cakes & yet their keels fell off with monotonous regularity. This resulted in a product recall on all centaurs to strengthen them. Despite this many didnt get fixed & in the last 10 years in our yacht club alone 4 Centaurs, 2 Konsorts & 2 Discus's have had severe hull to keel problems, two of these sunk on drying moorings (sheltered). The common thread on three of them was soft mud where the keels went in a long way & the keels got wrung as the boat lifted with the tide. Others just gave up due to long general use.
    Though it can be done its an absolute certainty to be uneconomic to do. You will have to gut the saloon down to the hull skin, strengthen the skin itself at each proposed keel location & fit at least 4 floors extending 2ft each side of the keel, you will use a lot of fibreglass, then you have to put all the bunks, floor etc back in again, much of this is structural to some degree. Then you have to source keels, on a Centaur sized boat they will be half a ton each, with an efficient splayed configuration you need a lifting gantry to hang the boat in to fit them. Out of interest the cost of reinforcing a Westerly Centaur properly by a boatyard is anywhere from £7500 to £10,000 You can buy a lot of yacht for that money ready to go. Your best bet is to buy a shallow draft boat that works, go sailing & eat steak.
  8. PAR
    Your idea can work, though you'll need nearly two tons of lead to replace what's being sold off the Pearson 30. You'll also need to engineer and build a couple of keels, which isn't a small feat, even if you're a reasonably skilled builder. Costs aside, this would be major surgery and will require a good investment in time and materials.
  9. GTom
    GTom New Member
    Were any of the sunken boats strengthened in the recall? I am considering a bilge-keel Discus, but this sounds very alarming. A keel loss is definitely one of the worst things can happen to a boat... Were 1980 Discus-es recalled? I suppose it wouldn't be economic to do the strengthening nowadays...
  10. keith66
    Several of the boats in our club had been "professionally strengthened" Not all boats got repaired in the recall. As ever a lot depends on who does the work & how it is done. Two of the Centaurs & one Discus that had been "strengthened" at a local yard subsequently had problems with leaking keels. I repaired one of these Centaur's & was amazed to find that the previous repair yard had just slapped extra layers of chopped strand mat down around the keelbolt nuts & surrounding area. But they had made no attempt to even clean the bilge first & had fibreglassed straight over the top of oily filth & ordinary bilge paint, no attempt at grinding the area clean had been made at all! I had to redo the entire repair including bolts. She is still sailing 5 years later with no problems. The other Centaur had been treated in a similar way by her own owner as well as the same yard & the stb keel tore off on the mooring. She was a write off.
    The Discus had also been professionally repaired & started showing stress cracks on the keel roots, her owner got worried & asked me to have a look. I found evidence of broken tabbing to bulkheads & floors. She had been surveyed the day before & passed. I was asked by the owner to just treat the delaminated tabbing locally. I declined the job as i could smell big trouble coming.
    I gave up working on GRP a couple of years ago. Got the ache with grinding glass!
    Moral is dont buy a Westerly unless you are 100% sure its been fixed properly & get your own survey done by a surveyor who knows what he is doing.
    Angélique likes this.
  11. GTom
    GTom New Member
    Thank you very much Keith, that was a crucial bit of information for my upcoming boat purchase! I knew about the issue for early Fulmars but nothing regarding the Discus. Any thoughts about the bilge-keel Moody 33? Alternatively I can go with a fin-keel Discus, however, that's a little deep for me.
  12. Jolly Amaranto
    Likes: 20, Points: 18, Legacy Rep: 207
    Jolly Amaranto Junior Member
    One thing nice about the bilge keel we had, never needed a special cradle when we pulled it for maintenance.
  13. keith66
    In fairness i did a large hull repair on a Westerly Konsort, another of the range that tended to have problems. That one had previously been strengthened by a good yard & broke her morning in a gale & went on the beach. She pounded for several hours against a concrete wall & smashed her side & side deck in. The aft corner of the stb keel was broken off. Her keels stayed on though there was some damage. She did well to survive at all.
    As for Moodys, i have never heard of any problems with them. Quite why a manufacturer like Westerly would get problems with one class of boat then repeat the same through their range for years is beyond me!
