Bhp?
Discussion in 'Powerboats' started by Laranjo123, Oct 17, 2011.
  1. philSweet
    Likes: 458, Points: 83, Legacy Rep: 1082
    philSweet Senior Member
    Stuck my foot in it again. Lets see if I can sort this out. Gonzo, you are right and I was wrong. I said rated horsepower where I should have said certified horsepower.
    replace rated hp with certified hp.
  2. Laranjo123
    Laranjo123 Previous Member
    Thx everybody i already got the BHP formula....tehehe
  3. daiquiri
    Likes: 258, Points: 93, Legacy Rep: 3380
    What BHP formula?
  4. Laranjo123
    BHP = SHP / ng where ng = 98 %
  5. DCockey
    Likes: 634, Points: 113, Legacy Rep: 1485
    DCockey Senior Member
    Incorrect. Advertised power in the US is power at the end of the engine crankshaft.
    The various methods to determine power for auto, tractor, boat, and other engines all determine brake power.
    Prior to the 1972 model year the SAE gross power test proceedure was usually used to determine auto engine power. This proceedure resulted in power ratings which were sometimes much greater than what the engine delivered as installed in the vehicle.
    Starting with the 1972 model year US manufacturers switched to the SAE net power test proceedures which result in ratings much closer to what the engine produces installed in the vehicle. European manufactuers usually used an equivalent DIN proceedure while Japanese manufactures used the equivalent JSAE proceedure.
    In the last five or six years manufactuers have been switching to the SAE certified power test proceedure which is a tighter test proceedure. The ratings for a number of engines went down but some went up when the certified test proceedure was used.
    Rated HP just means what the engine is rated at. In some infrequent cases it may be less than what the engine actually delivers.
  6. MikeJohns
    MikeJohns Senior Member
    BHP (Or PB) is a common enough term in ship propulsion although there is no formulae for BHP it is a rating . But you arrive at the required BHP working backwards.
    Engine
    BHP (brake HP)
    Gearing
    SHP (Shaft HP)
    shafting/ bearings
    DHP (Delivered HP)
    Prop
    THP (Thrust HP)
    Hull
    EHP (Effective HP)
    The loss ratio between any of the 3 letter power abreviations is the efficiency of the stage.
    Current convention is to remove the Horse "H" and write the abbreviation as: PB,PS,PD,PT,PE
  7. Laranjo123
    Yes it's true that you can't compute the BHP of the Engine it self. I've read that yesterday. Now my problem is. Where can i find engine with 2900-3000 bhp with 100-200 rpm?....
  8. MikeJohns
  9. Laranjo123
    Thank you mr MikeJohns...
  10. Laranjo123
    I have a question. Pd= (Pe x I) / nd
    What's the I stands for? The book didn't tell what's that I
    Pd= DHP
    Pe= EHP
    nd = 0.6
  11. Laranjo123
    Thx for the help all of you.....
  12. powerabout
    powerabout Senior Member
  13. MikeJohns
    700RPM is the engine. Don't forget the reduction gear. The prop speed is presumably the 100 to 200 RPM .
  14. powerabout
    Sure its just the thread starter that wanted a slow speed engine and I doubt there is one at 5000hp, I would be interested to know if there is one
  15. rxcomposite
    Likes: 608, Points: 113, Legacy Rep: 1110
    rxcomposite Senior Member
    The second question will be "Where do I get bowthruster?". With no reverse gear, how do you dock?
