best painting technique for 1-part paint in tight spaces?
Discussion in 'Materials' started by kayakingsteve, Aug 31, 2021.
  1. kayakingsteve
    Likes: 1, Points: 8
    kayakingsteve Junior Member
    What's the best technique you guys have found for getting 1-part poly smoothly painted into tight spaces, like foot wells in a surf ski or around hardware, where a roller won't fit?
  2. hoytedow
    Welcome.
    Try a brush. Wear gloves.
  3. kayakingsteve
    Likes: 1, Points: 8
    Touche' :) Foam brush or bristle? Tried with nice angled bristle brush first, but that seemed to leave a lot of grain... haven't tried sponge yet.
    Follow up question: is it practical to do a two-part paint over a one-part?
  4. hoytedow
    You may just dab it on with a natural sponge. No linear brush marks that way; just texture.
  5. kayakingsteve
    Likes: 1, Points: 8
    This boat is a beater, so a great boat to experiment on with glass and painting...
    Follow up question: can you do a two-part poly paint over a one-part?
  6. hoytedow
    Edit: No.
  7. Blueknarr
    Likes: 462, Points: 83
    Blueknarr Senior Member
    Try the triangular sponges sold on the make-up isle.
    It it usually not recommended to use a two part paint over a single.
    The two part frequently has solvents that attack most single pot paint. If it doesn't have immediate problems then all is almost OK. You won't get the adhesion benefits of the two part because the over painted single will fail under the two part. Kind of like painting over tape. Looks good until the tape lifts.
    hoytedow and kapnD like this.
  8. kayakingsteve
    Likes: 1, Points: 8
    FUNNY, it's almost as though building a boat and gelcoating and painting it is a complex process that requires a great deal of skill and planning. Who'd have thought. :) I sure bumbled into this, but it's been a great learning experience on a found boat. Nothing to lose and turning out a bit better than expected. Lots of things to improve on next time.
  9. fallguy
    Likes: 1,986, Points: 123, Legacy Rep: 10
    If brush leaves marks; use a capful of thinner.
    hoytedow likes this.
  10. mrdebian
    Likes: 12, Points: 18
    mrdebian Senior Member
    @fallguy does it need to be a specific thinner and what is the % per 100 gr for example?
    Can I use acetone as a thinner?
  11. fallguy
    It should be specific thinner for the paint. Recommend about 5% off the cuff, but manufacturers usually offer recommendations.
    glass test if in doubt
    paint on clean piece of glass no thinner
    Then 5% thinner
    Then 10% thinner
    see what looks best, simple as that, 10% thinner will cost some sheen, on my boat; used some thinner on last coat because it lays down so much nicer
  12. Barry
    Likes: 636, Points: 113, Legacy Rep: 158
    Barry Senior Member
    check with your paint store as there are product specific FIRMNESS of brushes as well. When you say bristle, are you meaning a bristle brush for oil base as compared to say a nylon brush for latex. There are also some for varnishes
    and stain that are softer and will feather out paint easier and with less texture/brush marks. Mind you if your one part paint is quite thick, an extremely soft brush will not move the paint around.
    The recommended instructions for two part poly paint, (when you cannot spray) is roll and then feather with a brush. You can buy rollers down to a couple of inches which will get into most areas. The advantage of a roller is that
    you can roll the paint in all directions and get an even coat before you feather
  13. The Q
    Likes: 43, Points: 28, Legacy Rep: 21
    The Q Senior Member
    if it's a really tight space get a fan blowing air in there, the fumes can be nasty, so nasty I had slight chemical burns to my legs through my overalls, lucky my head was above the chemical level..
