best method for removing concrete ballast
Discussion in 'Boatbuilding' started by robwilk37, Jan 31, 2012.
  1. CDK
    CDK retired engineer
    Several good ideas already, especially Hoytedow's dry ice.
    I would drill the holes he suggests, but pour hydrochloric acid in them and keep adding more when the foaming subsides. The acid breaks the cement matrix so you can spoon out the aggregate.
    This is a time consuming project, but it does work! I know a few guys who silently made a tunnel in rock that way.
  2. Frosty
    Frosty Previous Member
    I got to ask, if its in the keel and probably the shape of an Ice lolley mold could you not attach a lifting eye and haul it out in one go.
    I guess you wont be replacing it!!!
    I heard that you can now get spent Uranium that has timed out and is safe. I heard it is extremely heavy, maybe I dreamed it.
  3. keith66
    Likes: 31, Points: 28, Legacy Rep: 168
    keith66 Senior Member
    Couple of GRP boats i worked on had concrete ballast. Wasnt too bad to get out, drilled lines of holes & employed lump hammer & cold chisel. Both boats had bad osmosis issues under the concrete. Just to cheer you up!
  4. hoytedow
    Little dynamites, huh? Well why the h-e-double hockey sticks not?
    Just drill the holes smaller to be a better fit for the sticks!
  5. hoytedow
    There's a fine line between genius and insanity. I have erased this line.
    Oscar Levant
    (1906 - 1972)
