ondarvr
Senior Member
- Joined
- Dec 27, 2005
- Messages
- 3,221
- Reaction score
- 826
- Location
- Spokane. USA
I take it the green one is your current kayak and you want to slide it in where the rear round hatch is.
Go to one of the big box stores and look in the plumbing section, drain field pipe to be exact, it comes in various diameters so you may get lucky and find one that works for you. There is some very light double wall no hole pipe that might be the right size, normal PVC pipe fitting will fit on it, but you can't use PVC glue on it. Now you have a nice cylinder and PVC cap on the bottom, you can wrap some plastic insulation (bubble wrap stuff) around it, as many layers as desired. You can use a screw on, or slip on PVC cap for the top. This is cheap and light, plus takes an hour or so on a free afternoon.
The other option is to look at small plastic waste baskets, or similar food storage containers, they come in thousands of different sizes, then wrap with insulation. Some of these come with a lid, or you'll need to make one.
