I'm looking to add a new base to mount a pair of Group 31 batteries near the bow of my fiberglass boat. I have a good location selected right at the centerline of the boat along the bottom hull. Naturally this location has a subtle V shape to it (measured about 5/8" difference from centerline to ends).
The factory applied gelcoat to the fiberglass, so my plan is to rough up the thin gelcoat layer, then wipe with acetone. Then apply 3M 5200 generously, and lay a piece of 3/4" marine plywood on top of it. I will have the bottom side of the marine plywood bottom routered to roughly match the curvature of the hull for maximum contact area. Then, we will screw a piece of 1" plywood into the first, and paint the whole thing with gelcoat for water protection. Then I'll mount the battery boxes to that and wire them up.
Any feedback on this approach or alternate suggestions?
