Bertram 20 Main chine hight at transom
Discussion in 'Boat Design' started by bigjonny9, Aug 25, 2019.
  1. bigjonny9
    bigjonny9 Junior Member
    Here is the same angle as the boat you posted. Looks the same. If you go square On That’s where you see it
  2. Mr Efficiency
    Likes: 244, Points: 63, Legacy Rep: 702
    Might be an optical illusion created by light and shadow, in any case, nothing you can do about it .
  3. bigjonny9
    Yeah. That’s ok I’m fine with that. I was really just wondering what kind of impact it might have on the ride
  4. Mr Efficiency
    Going to outboards is probably pretty common with these old boats today, but they have extreme vee for a 20 footer and tippy enough with a heavier sterndrive, that is my reservation about the idea.
  5. kapnD
    Likes: 34, Points: 28, Legacy Rep: 40
    kapnD Senior Member
    I see some older fiberglass boats that have a slight rocker in the chine line, always assumed it was due to sag in the hullsides, especially in boats that carry a heavy cabin and sometimes a tower on the gunnels.
    Molds shrink and sag, as well as the hulls that come out of them, so the original plug might have been arrow straight, while later in production the hook grew into existence.
    A perfectly designed hull becomes functionally imperfect when exposed to variable external conditions such as sea state and loading, so a bit of compromise, as in a slight chine rocker may be a designed in as an attempt to deal with that.
  6. Mr Efficiency
    I think it's more an optical illusion than anything else, looking at the stern quarter photo, it isn't apparent.
  7. fallguy
    Likes: 104, Points: 63, Legacy Rep: 10
    fallguy Senior Member
    The porpoising has zilch to do with the chine. It has everything to do with the weight in the hull and the angle of the engines.
  8. Mr Efficiency
    Chine flats can affect porpoising, but as you mentioned, other things are well involved.
