Berkeley 5j5 jet pump
Thanks for the interest. The pontoons are/were finished. I outsmarted myself by filling them with 2lbs pu foam and they got way too heavy. Now I'm going to cut most of it out and go with the coosa. I'll try to post a couple of pics. The jet will be centered at the back of the deck which, I think, will be at the 11' foot mark rathan having the deck all the way back. The total width will 60" and the OD of the pontoons at the flange is 16". They are 16" deep at the deepest. I'm not settled on a hp yet but no more than 20hp, maybe 13hp or even 10hp.
The packing gland is essentially a seal that stops the water from coming in around the propulsion shaft of the jet.
How far advanced are the 12' pontoons that you are building? Can you post some photos of them perhaps?
And have you drawn any sketches showing the proposed arrangement for mounting the jet in a coosa board compartment between the hulls?
What make / size of engine are you proposing to install for propulsion?
Will it be sitting on the deck between the hulls?
Pics posted! Success!
