brian eiland
Senior Member
- Joined
- Jun 3, 2002
- Messages
- 5,320
- Reaction score
- 278
- Location
- St Augustine Fl, Thailand
DVD of Build Process & Drive System
We never did get a copy of this DVD ??
Abel Tasman Sea Shuttle working in the Abel Tasman National Park uses belt drives on some of their larger aluminum catamaran passenger ferries.
Basically they take passengers around the coastline of the park and drop them off on SHALLOW sandy beaches by beaching the boat.
Their problem was to be able to get their ferries close enough to shore to allow the passenger to disembark but not have the propellers digging up the sand.
They designed a belt drive system to be able to lift the props partially out of the water for shallow water operation.
Actually they designed and built two different types of drives, As this was several years ago there is a chance that some of what I put into this comment might pertain to one or the other type of drive as to length of boat etc but will get this information into the thread as to the viability of a belt drive system.
I rode on both of these taxis, one out and one back several years ago
Belt drive
25 meter aluminum catamaran, 150 passenger, twin Scania 485kw/600 hp diesels
The motors were above the prop shafts in an engine compartment that hinges just ahead of the front of the engines. When coming to shore the engine compartments were pivoted UP by hydraulic rams lifting the props partially out of the water.Ie the motor and props lifted up
I spoke to the captain about this unique drive and he put in a dvd on the in cabin screen that showed the entire build process of the boat and drive system.
Again from memory, I would expect that the ferry cruised at maybe 20 knots and the captain said that they had several thousands of hours on a set of Kevlar belts
Side pivot taxi
Not sure on the size of this boat ( maybe 15 meters) the engines were fixed but their outdrives which were designed by the owners, actually rotated outward on the axis of the input shaft to lift the props partially clear of the water
Two rather unique drives
