BC21 Water Ballast
Discussion in 'Sailboats' started by Roo2, Apr 8, 2025.
  1. Roo2
    Roo2 Junior Member
    Hi all - does anyone know how the water ballast works (flooding and draining) in the Swallow Baycruiser 21? The attached model shot is from their website.
    I think there’s a big screw bung through the hull under the circular hatch in the centre of the cockpit (yellow).
    There’s a curious pipe on the port side I can’t figure out. A vent of some kind?
    I’m also not sure of the extent of the flooding. Is the ballast contained under the cockpit floor or does it flood forward under the V-berth? All the light blue colour?
    Just curious that’s all! Thanks
  2. montero
    Likes: 82, Points: 28
    montero Senior Member
    I think that once the ballast is filled it can be emptied on shore. Unless the bilge pump will be in use .All the light blue colour is flooded.
    That white pipe is a voicepipe :D
    Some water trap vent probably.
  3. Roo2
    Roo2 Junior Member
    Thanks. I found a video yesterday that confirmed the ballast goes all the way forward (all the light blue).
    I’d like to know how the plumbing works. I saw in another video the “white pipe” changes to hose inside the cabin and appears to go into a 2-way valve which splits to two hoses that head toward the centreboard case. Curious..
  4. montero
    Not the same boat same builder :
  5. Roo2
    Roo2 Junior Member
    Thanks montero. That is an earlier boat from the same builder. As far as I understand the BR20 has a 300kg water ballast tank amidships that’s flooded and drained from a bung or venturi though the hull accessed from a screw hatch above it in the top of the ballast tank. I guess the BC21 is similar with a larger ballast tank.
