cracked_ribs
Senior Member
- Joined
- Nov 10, 2018
- Messages
- 160
- Reaction score
- 148
- Location
- Republic of Vancouver Island
this sounds extremely likely to me - in fact the one Johnson 70 I have worked on (by coincidence, I know we're referring to the Yamaha here) ingested a plastic bag which blocked the intake on a long run back in to Bamfield. Nobody noticed until the engine began to sieze and smell funny.@DogCavalry
Who knows how long that "starboard side grill" has been missing...
It may have simply ingested something small but big enough to jam the impeller.
Open up the impeller housing and have a look.
Hopefully, simply removing it will solve the problem.
Keep an active eye on that pisser until you get the "grill" replaced.
EDIT: It could even be a piece of the "broken" grill, sadly.
It got overbored, I forget by how much. Nothing crazy. We flattened the head back out by putting sheets of 400 grit sandpaper on a big piece of plate glass and taking off a few thou.
IIRC it was a '76. It still fishes off the west coast of Vancouver Island, and the only difference is that it now makes a tiny bit more power than it used to, presumably because the freshly machined cylinder walls sealed a little better afterwards.
Bottom line...you can have things go pretty freaking wrong, and still skate on major consequences.
