Bay boat hybrid hull design
PBC
Junior Member
Joined
Aug 17, 2020
Messages
33
Reaction score
21
Location
South Africa
Hi,
I am developing a hybrid “bay boat” with offshore capabilities. The boat will be produced commercially and hopefully for profit at some point. Construction will be GRP using vacuum resin infusion.
I am using Delftship to design the hull, 3 d printing prototypes and then I will build a 1/3 scale model / plug from mdf. Plug will be built from stations and panels cnc cut from delftship outputs.
Currently LOA is 6.7 m .
Max beam will be 2.5 m and beam on waterline will be 2.215 m. Beam can not exceed 2.5 meter due to road regulations.
Dead rise is around 18 degrees transom angle of 15 degrees. The boat has a reverse hook on the stern.
I am looking for input on the Bow entry : I have 2 versions both are convex between strakes. But with different entries. I would like to sharpen the bow entry As in the blue hull. any advantages or pitfalls associated with this. I am mainly concerned with broaching in big following seas and unpredictability in tight turns.
Thanks
I'm not convinced anyone has build a better one than the old(ish) Aquasports.
For heavier twin OB, inboard or I/O installation - more offshore oriented, look at the old(ish) Stamas hulls.
images
The "reverse hook" idea can't be seen in the pics, but is best avoided, if you want to get satisfactory results. Trim tabs are a better way to have the option of extra stern lift. Perhaps you should explain what you are trying to do, develop something for your own use, or to market it ? What material is the boat intended to be built from ? Hulls of this type are pretty well evolved, and unless you are very knowledgeable about what makes them "tick", it is unlikely you will come up with something that is as able, let alone better. I would say as a general observation that a deep forefoot is not as useful for improving ride, as some extra deadrise around the mid-body, and the stability won't be much different. It also encourages broaching, and is generally wetter, because a deep forefoot implies steeper buttock line forward.
Thanks!
I have edited my initial post. Also to clarify I am looking to design and build a plug to produce boats rather that attempt to design something revolutionary.
I will get some clearer photos . On version one the keel rises up from the baseline at around 3.3 meters from stern. Version 2 (blue hull)it rises up at around 4.7 meter giving the deeper forefoot and more dead rise forward of midship. You prefer version 1 in this instance? I suspect I can keep the keel on the baseline a little longer without the boat broaching...
I will upload picture and more detail of reverse hook.
Thanks
Sounds like a substantial amount of work and expense involved, is their a substantial market for high-spec ( infusion moulded) boats ? Do you have many local boats over there that are built that way ?
Aware of all the work and the expense. I think there is a viable market. Tooling cost for infusion will be roughly the same as for hand lay up. Infusion will allow me to work cleaner and have less labour And overheads. There are a few builders here that are experienced with infusion so I have access to experience in that department.
You might be better to 'flop' a good one, it is fairly common practice in Australia, to copy the best hulls of yesteryear, and adapt more modern lay-up techniques. Just make sure it can't attract legal action !
Here is our progress so far- would be interested to hear opinions. thanks
Busy with sanding. Will be fairing with mixfill 80 epoxy.Then epoxy primer followed by duratec vinyl ester primer and top coat. Tooling resin was going to be polylite but will now use a vinyl ester. Opinions appreciated. Thanks
Unusual looking boat, that forefoot and bow area has me a little worried.
Side view of the forefoot.
The pictures of the bow area at the framing stage looks different to the pictures you posted a short while after. A bit of an optical illusion. Is there a lines drawing to show ?
Lines drawings.
Thanks
That is a very, very complex shape indeed. I've never seen one like it. So there is no plan to use a test boat as the plug, and only make the mould if it performs to your satisfaction ? My first impression is that running down-sea it will dive into the back of waves before abruptly "bogging". It is quite fine in the waterlines forward, low down, but develops fullness very rapidly higher up.
