Wooden battens are perfectly suitable if the grain of the wood is parallel and straight. With a good table saw and the right wood you can produce good battens of any degree of limberness. The wood should be softwood only. That gives you plenty of options for selection. Hardwoods are less satisfactory.
For ducks...whales...or whatever, all you need are some weights. They need not be made of lead. A short section of round steel shafting with a sheet cork cover on the bottom works just fine. For laying out a full size loft, the ideal is to have a wooden floor and a selection of ice picks.....Or tin cans filled with sand.
Two and half inch diameter steel shaft weighs 16.69 pounds per foot. About three inch lengths are more than satisfactory for most drawing board use.
If you are determined to have traditional ducks, you can make your own with a bit of Plaster of Paris for a mould, and some lead. You can often get used lead alloy wheel balancing weights for almost nothing, from your tyre seller. The lead will melt in an ordinary sauce pan placed on the kitchen stove. I'd go for the shaft weights and let the machine shop or scrap iron dealer cut them to length. One caution! If you pour lead into a mould, the plaster MUST be thoroughly dry with no hint of water content. Molten lead and water do not get along well. Molten lead is also not friendly to human flesh. Use focused caution.
