Bass Boat floor drain replacement hardware ?
Discussion in 'Fiberglass and Composite Boat Building' started by northrivergeek, Jun 1, 2005.
  1. northrivergeek
    northrivergeek Resin Sniffer
    Ive recently rebuilt my boat .. when I got the bot the floor drain in the cockpit was missing, just a hole where the drain once was .. Ive looked and looked can't find a proper replacement drain. my floor is 1/2 thick with layer of glass on bottom and 2 on top.. I want something that looks good but the plastic or pvc to slightly extend below the floor so rot cant happen agin thru the floor drain. Every floor drain I find is 4" diamater hole and is maybe 1/4 inch of the plastic would extend down into the hole. I know what Im looking for must exsist just cant locate it want 2 -3 inch diamater hole and a 3/4 to 1 inch or more to extend down into the hole .. any help would be appreciated :)
  1. nanoskiff94
  2. Pat G
  3. thudpucker
  4. doggpound602
  5. Matt Duval
  6. DougDA
  7. vsslpr
  8. rebar
  9. hardguy007
  10. ber1023
