Basalt fiber
Discussion in 'Boat Design' started by Forecaddie, Apr 27, 2023.
  1. Forecaddie
    Likes: 6, Points: 8
    Forecaddie Junior Member
    Is basalt fiber better than fiberglass? Is it the cheaper version to carbon fibre? For 7 meter boat with diviny cell or 3mm ply?
  2. seasquirt
    Likes: 134, Points: 43, Legacy Rep: 10
    seasquirt Senior Member
    Hi Forecaddie, I just did a search for basalt fibre on google scholar, and found dozens of scientific papers of studies. From a quick scan it seems to have better properties than glass in many aspects, but there could be reasons not to use it in boats. It's been used industrially for decades, so a proper search should show up reasons why it hasn't been used that way. Could be due to economics, or lack of advertising, or convenient product, hegemony of glass industry, or critical failure in a marine environment. There are many polymer related papers, and hybrids of different fibres with basalt fibre. Have a good read, and then you tell us if it's better or not, and why.
    rwatson likes this.
  3. Forecaddie
    Likes: 6, Points: 8
    Thank you- I thought I would ask the community of boating specialists before wasting my research time.
    I will come back to you.
  4. Tiny Turnip
    Likes: 283, Points: 63, Legacy Rep: 743
    Tiny Turnip Senior Member
    rwatson likes this.
  5. catahoula
    Likes: 8, Points: 3
    catahoula Junior Member
    Basalt fiber is interesting, but it's also hard to find, and has only marginally higher properties than e-glass, while having lower properties than s-glass as well as lower elongation. I'm skeptical of any sustainability arguments as both glass and basalt need to be melted down with a lot of energy. Glass is ~70% silica and basalt is ~50% silica; overall they're more similar than different so get what is cheap and available.
  6. Rick hambric
    Rick hambric Junior Member
    i find its insulation and heat deflection properties very interesting. the biggest reason you don't see a lot of boats being made from it is its not readily available. the #1 exporter of basalt raw materials is Russia. so the availability of it over the past 3 years has decreased. Performance wise, it isn't quite a halfway point between e & s, but it is more abrasion resistant than e. so if you're looking for something a little tougher than e, cheaper than s, then basalt or (R-Glass) is the right product for you. it is a tad stiffer than e glass and you will see some bridging problems, if you don't pay attention.
  7. RainAndStorm
    RainAndStorm Junior Member
    I wrote a small article about it, have rolls of it from Basaltex, about to get "G-10" made out of TENRON (AKA FILAVA) from Isomatex.
    You can talk to either Basaltex or Isomatex if you need more info, great people.
    https://www.patreon.com/posts/volcanic-fibers-97832482
  8. TeddyDiver
    Likes: 146, Points: 73, Legacy Rep: 1650
    TeddyDiver Gollywobbler
    I'm using also basalt fibre (mostly glass and some carbon), great stuff IMHO..
  9. Kirill Yakushin
    Kirill Yakushin New Member
    Hello. I've noticed your interest in basalt fiber. I represent Basalt Uzbekistan, the one and only manufacturer of basalt composite materials in Central Asia
    basalt roving
    basalt chopped fiber
    basalt rebar
    basalt geogrid
    basalt pipe
    basalt fabric
    If you are willing to get a sample of our product feel free to contact me.
