Ballast question
Discussion in 'Sailboats' started by infy, Feb 3, 2019.
  1. infy
    Likes: 1, Points: 3
    infy Junior Member
    Sailboat design forum seems like the appropriate place to ask.
    So I occasionally observe conversations about rolly and uncomfortable conditions on the hook. Seems like a fair complaint.
    Sure you can do some anchor tricks.
    Why not hang some ballast bladders off the cleats port and starboard? Inflate them with 1000lbs each and drop them keel level. Or lower if available.
  2. tpenfield
    Likes: 38, Points: 28, Legacy Rep: 10
    tpenfield Senior Member
    What are you inflating the bladders with? Water?
    Keep in mind that water has neutral buoyancy in water . . .
  3. infy
    Likes: 1, Points: 3
    infy Junior Member
    Right, it would be like inflating a balloon for ballast out of water.
    You would keep them above the water line. I made an error above about dropping them. But above the waterline probably won't help.
  4. jehardiman
    Likes: 1,354, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    Roll stabilizers (i.e. flopper stoppers) have a couple of centuries of use.
  5. infy
    Likes: 1, Points: 3
    infy Junior Member
    Anyone have first hand experience with the flopper stopper systems on a sailboat?
    I've seen the Paravane systems with fish when under way. Like motor nordhavns.
  6. jehardiman
    They work, you just have to get them down below the wave orbital that effects the rolling (i.e. ~ 1/2 wave height+3 x vessel's beam). Then there is the storage and handling issues.
