Bad Monterey gas gauge
Discussion in 'OnBoard Electronics & Controls' started by PAK RAK Man, Sep 23, 2011.
  1. PAK RAK Man
    PAK RAK Man New Member
    I have a 1999 19' Monterey and it seems most of the gauges have gone bad, but a real problem is the gas gauge. Anyone else have this issue, and is the fix, the sending unit or gauge itself? Appreciate any advise
    Likes: 2,316, Points: 123, Legacy Rep: 2031
    If you short the pink wire to ground and the gauge moves, it is the sender. A sender and gauge set is not much more expensive than the sender alone. Changing both will make sure there is no problem. This assumes there is power to the gauge now.
