Axopar hull style
Discussion in 'Boat Design' started by A B, May 1, 2019.
  1. A B
    A B New Member
    Hello,
    I did a search, but I could not find any discussion of the hull style as seen on the Axopar 28. There seem to be quite a few European boat companies creating boats with these similarly shaped hulls. Boattest just did a review of the axopar 28 and came away impressed with its rough water performance.
    It appears that these hulls are narrower and their bow area is sharp without any flair. One company that has done a few of these types of designs is named Navia Design.
    Has this already been discussed on the forum? Is this really a new style?
  2. BlueBell
    Likes: 1,240, Points: 113
    Axopar is a good compromise in hull design for around here.
    Pricey, but good.
    Nothing is new any more in boats...
  3. Ilan Voyager
    Likes: 237, Points: 63, Legacy Rep: 758
    Ilan Voyager Senior Member
    Welcome to the forum.
    Nothing new. This style of hulls appeared beginning of the 20th century on seaplanes as the steps impedes the suction down of the hull by the flow of water, thus the seaplane takes off with less power and/or a shorter distance. Maybe there has been similar designs on fast boats at the end of 19th century when all the big navies were in a frenetic search of very fast boats and ships powered by steam turbines.
    For sure, that had been tried on motor boats since at least 100 years, specially on race and speed record boats.
    There are many different variants on stepped hulls, the number and position of the steps being a lot of black magic. The purpose is to inject air into the water flow thus getting an air lubrication, and getting flow separation.
    Most of these hulls, as you can see on the Axopar, have very full water entries, and that gives very harsh boats if the water is not mirror flat.
    A lot of these hulls have had the lateral track stability of a soap bar sliding in a wet bathtub.
    A summary about hull bottoms.
    Hull Bottom Technology - BoatUS Magazine https://www.boatus.com/magazine/2018/april/hull-bottom-technology.asp
    A technical article.
    Stepped planing hull – pros and cons | JP Marine - Marine Engineering http://www.jpmarine.pl/stepped-planing-hull-pros-and-cons-2/?lang=en
    The 2002 Hydrafoil catamaran by Yves Parlier.
  4. Magnus W
    Likes: 13, Points: 18
    Magnus W Senior Member
    The key to getting a seaplane airborne on is to not let the part of the float aft of the step in the water while ”on the step”.
    The aft part is mostly just for stability while going slow and has little to nothing to do with whats happening when on the plane (ie step).
    So the step has not the function of air-lubricating the aft part of the float, as is the case with Axopar. And as you can see on the Beriev, although not a very good example, the hull after the step as angled upwards, to allow pitching up without dragging the tail, while the Axopar runs parallel.
  5. A B
    A B New Member
    Thanks for the details discussion. Would that kind of bow entry help reduce slamming in rough water if you keep it at semi displacement speeds, since more of the bow is already in the water? Does the step reduce the semi displacement region?
  6. Ilan Voyager
    No, these hulls are for very fast boats with lots of power running largely in the planning zone. The bow entry would not reduce the slamming at rather low speeds, and the step or steps becomes really efficient at rather high speed. These boats are not meant to stay at low speeds, displacement and semi displacement. It's not their purpose. Steps hulls are generally specialized for high speeds and ask for generous amounts of power.
    In the case of the Axopar the steps are more "trenches" to generate a suction of air than changes of angulation of the surfaces of the hull thus interruption of the water flow.
    To get out of the hole or pass the hump the keel angle, the planning surface, the center of gravity, the angle of attack and the angle between the propellers and the hull will be more important. That's where outboards, Z drives or surface drives will shine as it's possible to adjust the trim and orientate properly the thrust given by the propellers.
    Hulls have to be designed for the wanted speeds, and become rather inefficient when driven out of these speeds. Also hulls have to be designed also for the sea state that are more likely to encounter, ie the conditions of winds and waves prevalent in their zone of navigation.
    That you win by one side, you'll have to pay it on the other side.
  7. Joakim
    Likes: 53, Points: 28, Legacy Rep: 422
    Joakim Senior Member
    Pricey? Axopar is a cheap new generation of this XO Boats - Design by sea https://www.xoboats.com/ , which cost 2-3 times more.
    Same group of people started both companies and designed the boats. They sold XO company before starting Axopar. Axopar name is a combination of brands they have started before (Aquador, XO and Paragon).
    Long and narrow is the key to good rough water performance.
  8. gtflash
    Likes: 0, Points: 16, Legacy Rep: 10
    gtflash Senior Member
  9. rwatson
    rwatson Senior Member
    Great article. It really needs greater emphasis
    "The Rafnar Hull is a revolutionary hull-and-keel technology that will ultimately disrupt marine industries globally. Confirmed by independent research to be capable of up to 95% fewer slamming impacts than competing deep-v hulls, the Rafnar Hull ensures otherwise unattainable seakeeping in the most extreme marine environments. "
    Exceptionally smooth and comfortable due to limited slam on waves."
    Significantly reduced slamming results in less mechanical and equipment fatigue, extending the lifetime of expensive electronic equipment on board.
    Greater on-board safety from significantly reduced slamming means reduced risk of injury, lower crew & passenger fatigue and related costs
    Precision performance without compromising cruising or top speed.
    Immediate handling response with no sliding
    No wake created behind the vessel, resulting in less water disturbance
    Exceptional stability and balance when idle and at speed
    High payload capacity without compromising cruising or top speed
  10. Mr Efficiency
    We can't learn much from a boat running beam on to some chop, it really is the most "friendly" angle.
    BlueBell likes this.
  11. Magnus W
    To my eye it seems to run pretty smooth for the size of boat and sea.
  12. Mr Efficiency
    As do most boats, at that heading, but turn into the sea, and let us see what happens. I think I already know the answer, you get hammered. Or they'd have been at pains to illustrate its capabilities, if it were otherwise.
  13. bajansailor
    Likes: 1,811, Points: 113, Legacy Rep: 37
    bajansailor Marine Surveyor
  14. Mr Efficiency
    bajansailor, those two boat tests are of stepped vee-hulls, not boats with the "new keel technology "
  15. bajansailor
    But isn't AB's original post about the stepped hull Axopars?
    Hence why I posted the video links for reference.
