AUV propeller question
Discussion in 'Props' started by Rocket888888, Mar 2, 2018.
  1. Rocket888888
    Rocket888888 New Member
    Hello. I'm trying to generate 10kgf at 4kts from 300W shaft power (it is to power a smallish AUV). Max torque is *probably* about 3Nm and diameter <300mm.
    Don't really have any practical experience of propulsion though apart from what I have devoured from Gerr and Carlton textbooks so please bear with me!
    I have some series data for things like the B-series and ducted Ka (and a very helpful manufacturer willing to make whatever I request!) and have identified potential propellers from both those series but I'm kind of making it up as I go along and wondered if there was either a) a more comprehensive database somewhere (either for sale or open source) of Kt/Kq/J or simply b) a propeller that wiser people here would recommend I look at.
  2. jehardiman
    Likes: 1,470, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    You have Bp-sigma diagrams?
    Lets use them.
    10 kgf = 98.1 N
    4 kts = 2.05 m/s
    98.1 * 2.06 = 201 Nm/s = 201 kW = effective Horsepower desired
    300W = 0.402 hp = delivered Horsepower
    minimum eta = 201/300 = 0.66 which is reasonable for a open B-series but a little high
    for a ducted design point (Bp > 30).
    Let's assume you want high efficiency so we will start with a B-series 2.38 with assumed Bp = 5
    Bp = 5= n (0.402)^0.5/(4)^2.5
    n = 5(4)^2.5/(0.402)^0.5 = 160/0.634 = 252 rpm
    D = 300mm = 0.984 ft
    sigma = 252(0.984)/4 = 61.9 which gives a P/D > 1.4 so wee need to increase Bp
    Quickly optimizing we get
    n = 755 rpm
    Bp =14.95
    sigma = 185
    eta = 0.68
    P/D = 0.8
    So it is possible to use a 300mm dia B2.38 with a P/D of 0.8 to power the AUV. Your problem now becomes gearing the motor to deliver 3.79 Nm @ 79.1 rads/sec with 0.98% efficiency.
    Looking at a B3.50, eta is approximately the same but P/D increases to 0.82 while n drops to 650
    A B4.40 seems to offer the best solution with a P/D =0.97, n= 550
    Improving the aspect ratio of the propeller area (i.e. more thinner blades) will help, but then you are into a custom prop. If you are willing to go to a special design, then the polynomial coefficients for the B series can be found in the 1988 edition of PNA Chp VI, Sect 8, Tbl 17.
  3. gonzo
    Likes: 2,293, Points: 123, Legacy Rep: 2031
    I think the first calculation is whether the AUV can attain 4 knots with 300W.
  4. jehardiman
    Yes, the first lines are to see if it is possible to attain 201W effective HP with 300W delivered HP. Based on what I saw during the few minutes I spent on this, it seems like a class problem, the requirements kept falling near the max efficiency line for the standard Bp-sigma charts. Nothing really strange. But it really needs a custom 2x2 counter-rotating prop set to optimize 300W dHP.
  5. gonzo
    I meant that the AUV may be the size of a torpedo and will need more than 300W to reach 4Kt.
  6. jehardiman
    Oh, I see your point. But the OP started this thread with a required thrust of 10 kgf @ 4 knots so I assumed he had already made that calc. FWIW, 300W @ 4 knots for a 21" (~525mm) diameter torpedo sized AUV (based off a stated prop of 300mm)
    is about right
    , provided it is well shaped (i.e. no FLS). This is very close to what a well shaped 750mm diameter Human Powered sub requires at 4 knots.
