layout tools for ellipse
Discussion in 'All Things Boats & Boating' started by junkdog, Feb 27, 2007.
  1. junkdog
    junkdog New Member
    i'm noob to your forum.
    I was wondering about laying out ellipses and very large arcs with a mechanical device. ive seen some type of plastic rule that is able to bend as each joint slides over one another. I have not been able to find out the name of this device or where i could get one or how to make one . i bielive it comes from oldschool boatbuilders. can anyone help me with a link ,a name ,a drawing, anything. i build concrete skateparks and am looking to use something like this for onsite shape building .The shapes you use in your hulls and so forth are very simular to some skatepark elements. any info would be greatly appriciated
    thanks
  2. SamSam
    SamSam Senior Member
    If you go to Google 'images' and put in 'ellipses' various tools and ways to draw them come up. Sam
  3. safewalrus
    Likes: 78, Points: 0, Legacy Rep: 659
    safewalrus Ancient Marriner
    Is that total or patial ellipses?
  4. waikikin
    waikikin Senior Member
    Junkdog, try two nails & a loop of string.Regards from Jeff.
  5. junkdog
    junkdog New Member
    i was interested in partial ellipses i have used several methods which include string and two points as well as a board with two sliding pivot point that are constrained on the x and y axis but in order to draw a 10-13 foot radius you need a lot of shop space and the aligmen of those point s on a sheet of ply is difficult at best i was thinking of something simple that would be easy to use if it exists thanks for your input
  6. Poida
    Likes: 51, Points: 48, Legacy Rep: 497
    Poida Senior Member
    If you want to be a really safe Walruss you'd use a pinhole camera.
  7. safewalrus
    Poida, your right in each case protects the eyes no end, unlike certain people who ain't getting the joke!:D :D :D :D
  8. Lancerbye
    Lancerbye Junior Member
    Have you tried long strips of oak or fir sold as stop trim and a couple of nails?
  9. VKRUE
    Likes: 12, Points: 28, Legacy Rep: 64
    VKRUE Just another boat lover
    I tried the nails and string a couple of times... seems one has to maintain a certain (precise) tension on the string.... didn't work well for me.
    Used the old bent, warped and twisted beam as a model to copy from, clamped it to my workpiece for marking and then cut (leaving extra meat on the cut).
    Then planed (scarf actually) the surface proper by eyeball.
    Didn't need the pinhole camara either as it was a total elipse of my heart.:p
  10. dimitarp
    Likes: 4, Points: 8, Legacy Rep: 19
    dimitarp Junior Member
    A way to layout a ellipse is to use two nails and a length of string
  11. safewalrus
    or get somebody else to do it!:cool:
  12. Lancerbye
    That sounds like a good plan.
