Attachment file size
Discussion in 'Forum Questions and Suggestions' started by gonzo, Mar 22, 2017.
  1. gonzo
    Likes: 1,723, Points: 123, Legacy Rep: 2031
    Is there some way to attach a file that is larger than 10 MB?
  2. Boat Design Net Moderator
    Likes: 166, Points: 43, Legacy Rep: 1004
  3. gonzo
    Do I need to give access to dropbox, or is the link read only?
  4. Boat Design Net Moderator
    You can share a large dropbox file as view only. In dropbox when looking at the file, click the share button, verify link settings are "can view" and not "can edit" and then copy the share link. Then anyone can download that file with that share link. (If you create a shared folder, be sure you set it to "can view" and not "can edit")
< spell check turned off in edit screen? | uploading pinterest images >
