thenavalarch
Junior Member
- Joined
- Oct 25, 2013
- Messages
- 90
- Reaction score
- 16
- Location
- Singapore
Hello and greetings from TheNavalArch!
We’re pleased to publish a new article titled ‘Draft Surveys - Methodology, Calculations and common errors’.
A draft survey is an effective tool for the correct determination of the cargo loaded/discharged from/to the transporting unit. However, there are several intricacies involved in both conducting the survey, and the follow-up calculations. This article explores the topic in-depth, with detailed explanations of calculations involved.
Article link:
Draft Surveys: Methodology, Calculations, and common errors - TheNavalArch https://thenavalarch.com/draft-surveys-methodology-calculations-and-common-errors/
Regards
Team TheNavalArch
