Catfish Howard
Junior Member
- Joined
- Nov 2, 2021
- Posts
- 37
- Reaction score
- Location
- Panama City FL
I have 1990 20' bass buggy - 60 HP Johnson - I think it weighed around 1275 lbs when sold but I cant find any manufacturing stickers (it might be 21'). I took off all the furniture that was on the boat when they sold it so the weight of 1275 lb is more likely closer to 875 lbs now.
I just moved to Florida and like going out for 3 days/2 nights which mean I have a lot of extra weight. I figure with batteries, gas, tackle, people, cabinets and so on I have about 1600 lbs added to the boat/motor weight. The floors rotten and the steering cables rusted so I figured it is time to restore the boat. With all my added weight around 1600 lbs + 875 lb boat/motor = 2475 lb that the toons need to support.
The pictures you can see the water level in front is 12" from the top of the toon and the back the water level is 6" from the top and this was with about 2100 lbs this weekend and with 600 lbs up front.
Will these 21" diameter toons be safe if I can even out the weight from the front to the back trying to get the water line more even or is it supposed to be lower in the back? Or would it best to add a 3rd center toon if I can find a 21” or should I replace the two 21" with 25" toons? I want to be as safe as possible particularity since I'll be in salt water and you never know what kind of wave might hit you from other boat or barge waves.
