Approximate cost of a one-off 29er like boat?
Discussion in 'Boatbuilding' started by 1gerry, Jul 21, 2013.
  1. 1gerry
    1gerry Junior Member
    Hello all,
    I am new in this forum.
    I have been doing lots of research recently, and I would like to start building a sailing skiff, similar to a 29er, or a javelin (http://javelins.org/Technical/buildyourown/buildingIndex.html)
    Can anyone give me some kind of indication of how much I could expect to spend to build a complete boat like this in plywood(rig and sails included)? And what would be the cost if I were to make it in fiberglass?
    I am under the impression that a marine plywood boat would be faster, easier and cheaper to build than a foam core fiberglass one. Is this correct?
    I've also read somewhere that it would take something like 500hrs to build the hull. Is this correct?
    Side note. I am in Canada. I have a little bit of fiberglass and woodworking experience. I am an industrial designer, so I am quite good at figuring out little construction problems.
    Thanks to all!
    Regards
    Gerry
  2. rwatson
    rwatson Senior Member
  3. DCockey
    Likes: 677, Points: 113, Legacy Rep: 1485
    DCockey Participant
